[NEW Android App] Phone Tracker - GPS Tracker
Phone tracker is a real-time GPS location tracking app that ensures you can safely monitor the whereabouts of your loved ones.
Phone tracker was designed to primarily for find location by phone number, the gps tracker app aims to capture the real-time location of users. It then logs this data, providing an insightful map of the user's movements. The heart of this app, Locato, functions through mobile devices—be it phones or tablets. By utilizing advanced geolocation technologies, including GPS, Wi-Fi, and cellular signals, Locato promises pinpoint location accuracy.
Key Features:
Real-time Location Tracking: Get immediate updates.
Location History: View past movements and patterns.
- Duration Logs: Understand how much time is spent at particular locations.
- Battery Status: Receive immediate updates on your contacts' battery levels.
- Sound Profile Checks: Understand if a contact’s phone is on silent, especially when they’re unreachable.
- Battery Efficiency: Continuous GPS usage in the background may impact battery longevity.
- Remember, with great power comes great responsibility. Use phone tracker wisely and respect individual privacy.
Google Play: Phone Tracker - GPS Tracker - Apps on Google Play
Please Help! Lost all of my home screen website shortcut icons
Why changing a VPN setting would do this is not obvious to me, but it's clearly happened.
Thank you all for the responses.
I am told by someone else that when you set up the alternate DNS, it encrypts the URLs of the Website shortcuts and that is probably why it deleted them when it was disabled. Not completely sure this is correct, but sounds plausible even though many of those links were set up long before the private DNS.
Yes, I am convinced they are lost forever.
I did not like saving the shortcuts this way, but it was convenient and easy to access them. Some of them, like a link to Google Tasks eliminated the need to install the app. Others were just saved that way because it was easier than bookmarking for the reason I already gave and I was pressed for time.
I had planned on backing them all up one day or copying them or even manually storing them in a text file but the last time I checked there were really no good ways to deal with these shortcuts in bulk (like converting them to bookmarks). So I put it off and paid the price.
Too late now! Oh well.
Thanks for all the replies.
PS: For some reason it also deleted some (but not all) of my Widgets. Looks like the ones it didn't delete might have been for the stock built in apps. This wasn't a big issue and I was able to recreate them. But it is puzzling why it would do that especially since to my knowledge those Widgets had nothing to do with the Internet and I can't see why they would even have access.
Help Can no longer select SIM cards for calls on Motorola Edge 20 Pro
I think this might help. Follow this, and reset the calling SIM preferences.
To do it through Google Dialer/Phone app
Phone app >> 3 dot menu in the top-right >> Settings >> Calling accounts (Under GENERAL) >> Voice calls (Under 'Make and receive calls') >> Always ask
To do it through the system settings app
Settings app >> Network & Internet >> Internet >> Settings icon beside your carrier name >> SIM preferences >> Voice calls ('Under Preferred SIM for') >> Always ask
Reinstall Android without losing apps + data?
If you are flashing the same ROM .zip file that was installed previously then you should be able to do so without doing a factory reset in the process. So if it's the same ROM, and if your data haven't already been deleted, this should be possible.
Now I've never heard of OrangeFox so don't know whether there is any quirk in its interface, such as it doing a reset by default when you flash a ROM. The recoveries I used in my ROM flashing days, including the most widely-used one (TWRP) kept such things separate: you just flashed the ROM, and it was up to you whether you did a reset or not. But if you didn't choose to do a reset when flashing and the data were gone then maybe you need to do something special with OrangeFox to tell it not do a wipe (the opposite of what other recoveries do)? Or maybe the data had already been deleted by whatever corrupted your ROM, and so nothing you did could have saved them.
I am however curious about this "recent upgrade": custom ROMs don't generally receive over the air updates, you update them by flashing a newer version of the ROM. So what exactly was this "recent upgrade", and what exactly happened (as this might give a clue as to what happened to your data)?
Of course if you flash a different custom ROM from the one that was previously installed it's likely you'd need to do a reset anyway, since the system data and settings will almost certainly be incompatible. If it's based on a different base (e.g. AOSP vs a manufacturer's own customised Android) or a different major version of Android then you almost certainly need to do a reset.
If you have a custom recovery and don't want to risk losing stuff then take a backup using the recovery every now and then (a "nandroid" backup) and keep a copy on some other device (SD card, flash drive, etc). If your ROM is rooted you can also take full app and data backups: Titanium Backup used to be the go-to app for this, but I think it's not been in development for a while. I've heard that there are alternatives, but as I no longer root I don't keep up with such things.
Web audio recording - microphone disabled during screen lock
I'm developing a web app that uses audio recording. The issue I'm facing is that when the phone locks after inactivity, Android shuts down the microphone, probably due to a security policy.
I'm not aware of any way to allow a website to keep the microphone on during a screen lock.
Is anyone aware of how to shut this behavior off, or work around it? I think a mobile app can probably do it, but I'm wondering if a web app can.
Thanks for your help!
Camera colors on different phones and where are my threads
No, I haven't done that but it would be a good idea. Probably the main difficulty is the cheapness of the Moto G Pure (sub $50 at walmart). The Nord might not be super expensive but it likely has overall the better specs. As for pink/red, blue/green etc., I might have been exaggerating somewhat. It's just frustrating to see a color in real life and not be able to capture it properly.
Can't Logon To Forum Anymore
I am not impressed with how the "kids" want their internet served, I wished I could still have the XP Pro OS !
I do not like touch screen, Ipad look, tablet look, or any other "fad" that is going around, just deliver my content to my device and let me alone.
The world changes everyday, and if we do not change with it, we will be left behind ....
Thnkx to Rob for wanting to keep us "in the game".
Operation Zombie D Episode-1
In a place people were attacked by a virus called zombies. No human being left there. it seems like a forest. So, in order to get rid of this zombies soldiers came with an operation Zombie D(Dark). Firstly one soldier got down from army chopper zombies killed him, and again another soldier is getting down by seeing this zombie crashed the army chopper. But unfortunately only one solider had saved he should destroy the zombie with weapon only. From here game starts
Download : Operation Zombie D Episode-1
Operation Zombie D episode-1 is FREE on Android!
Game Features :
• NO in-app purchase
• Use 5 different weapons
• Action game with interesting Zombie-shooting
• Kill different kind of zombies
• Zombies are also having weapons
• Some Zombies die instantly and some are very hard to die
How to play :
• Select Gun and shoot the Zombies
• Tap the special button while choosing shot gun
• Use special power weapons
• Use limited bullets and try to walk more distance.
Nokia c100 hard reset/pattern bypass
On step #9 in part 1 i got this error:
FAILED (remote: unknown command)
finished. total time: 0.000s
For part 2 steps 1 and 2, im not sure which website to go to.
other than these my pc is recognizing the device and it seems to be working.
Stop wasting time trying to do a Factory Reset to bypass the Lock screen. When you set up your lock screen pattern, that was saved within the installed Android operating system on your Nokia C100. It was not saved in your user account stored in your phone.
Note that with Android, there's a clear distinction between the OS and the user account.
The internal storage inside your phone is divided into several separate partitions. Most are dedicated solely to the operating system and are protected and restricted by system-level permissions. One partitions is set aside as a general, user data partition. That user data partition is not protected and only has user-level permissions.
And that has a lot of relevance to your situation. A Factory Reset only wipes that user data partition clean, it does nothing to any of those system partitions. So doing a Factory Reset wipes off your saved user account data, but again that isn't where the Lock screen config data is stored. You need to focus on actual problem, reloading the existing Android OS with a 'clean' version. With Android that's commonly referred to as flashing the ROM or flashing the firmware. Flashing the stock ROM will result in an OS that has no lock screen enabled.
Does your Nokia C100 have an unlocked bootloader?
I gave a Nokia N152DL to my friend, but no matter how many different ways i try, this phone will absolutely not allow me to perform a hard reset. I also am only able to get a ..."Fastboot On"... in the lower left hand corner of my screen. No matter if I push volume buttons or the power button, nothing changes.
Any suggestions on any secret methods that i can use for this the Nokia N152DL?
Can't send MMS
I know you said "network settings reset", but I'd specifically go into them and check the APN (Access Point Names) settings and make sure they are correct for Straight Talk. Some providers use 2 APNs, one for regular mobile data and a different set for MMS, so it's possible for mobile data to be working but MMS not. You should be able to find the correct settings on your provider's website.
Can anyone tell me what these icon symbols these are from
ii agree with everything that @Hadron said. but i also just want to add to it:
we get this question almost every day. the problem is that there are millions upon millions of apps with their own notification icon. so unless it is something popular like facebook or youtube, most of these questions go unanswered. most of the time we can only give guesses as to what the icon is.
so do not hold your breath thinking you will get an actual answer from us.
eclipse video sensitivity?
I'd like to use a Nexus 6P to video the total solar eclipse on August 21 2017. The idea I have is to use a tripod to allow video tracking since well before totality at my location, until well after when a large part of the bright solar disc is again visible.
Would any of this cause damage to the Nexus 6P camera or display, please?
I'd like to "bump" this topic please, to help those with the 14 Oct 2023 annular eclipse.
Drag the Windows 11 screen with the mouse, like you do on Android
Ever since I've been playing Android games on an emulator on the PC (for the larger screen and better sound), I've got used to dragging items with the mouse, and scrolling the screen with the mouse (as in holding the left button and dragging). I now find myself trying to do this in Windows, say on this webpage instead of using the scroll wheel. I found this program - GitHub - Mikhail22/drag-scroll--autohotkey: AHK scripts - but it's very old (Autohotkey said it needed to install an older version) and seems not to tell Windows quick enough to scroll the other way. It moves the screen the wrong way for about 6 lines, then goes the right way.
Any better ways?
WhatsApp only exports media from last few days
So I've just found a way to backup the whole thing (all of my chats and media) to my PC, using an app called WonderShare Dr.Fone which I downloaded for Windows 11. But a big problem is it's encrypted (since the backup process requires enabling end-to-end encryption backup in WhatsApp with a 64-bit key) and the software doesn't seem to have the option to directly view or extract the encrypted data.
I guess it's better than nothing, because supposedly this data can be transferred to WhatsApp on a new device as it presents that option, and may be theoretically extractable by other programs?
However, if anyone finds out how to view or extract the encrypted data (given I know the 64-bit key I generated), or know of another software that enables a more transparent backup, please chime in.
In the meantime, I guess I'll have to sift through my chats and download any media I don't have yet I may want to keep, in case I don't have access to these later (planning to change phones soon).
A few tips for the software: you'll prob need to also download the "Dr.Fone Link" mobile app for Android, and after connecting your phone by USB, will need to enable USB File Transfer, Developer Mode, USB Debugging (the app will guide you through the latter 2 if not enabled yet). In the desktop app settings, you can specify where to save the backup. If you don't specify a path, it will save directly in the C drive. For the WhatsApp backup process in Dr.Fone, unfortunately a 64-bit key is required; won't accept a standard password.
Filter
