World Art Puzzle is a classic 15-puzzle game that consists of a painting of numbered square tiles in random order with one tile missing.
You have to slide the tiles to reassemble a painting, by touching the block you want to move.
Game contains:
- 11 themed galleries with a total of over 300 paintings;
- 2 levels of difficulty: with 15 numbers (easy mode) and without numbers (hard mode);
- 43 achivements;
- 1 musical theme and 17 sounds;
- earn game's diamonds for every solved puzzle;
- diamonds can be spent on adding painting to collection or puzzle shuffling;
- added ability to delete a painting from collection;
- help system and detailed descriptions about paintings, genres and artists;
- the game is localized to English, Ukrainian and Russian languages;
Thanks for your post. My Tecno F1 apps have crashed, I mean, all my apps keeps crashing. I downloaded some stockrom version which flash tool has failed to load. Therefore I want the original version that came with it (f1-vp510efg-go-191023v15), so as to know what the problem really is. I'll appreciate your contribution too. Thanksfirst off this is not news.
second have you looked at techno's website to see if they offer updated firmwares for your phone?
third....what happened? why do you need firmware?
So odd that so many didn't work. Now I'm curious if I would have the same problem with others. Glad it worked though and thanks for letting us know.Gee thanks. That worked. I had tried 4-5 file managers and none of them worked. This one did the trick.
Lee
apparently? i do not know about that. there is always ways or work arounds to be found.Apparently there is nothing
On se fait beaucoup attaquer inutilement donc de l'aide nous ferais du bien.
Merci pour ceux qui accepterons de venir aider mon alliance.
yes?????We get attacked a lot unnecessarily so help would do us good.
Thank you for those who will accept to come and help my alliance.
i thought this was real for some reason...LOL
My old S3 is my bedside clock/radio and my car GPS. Don't use it as a phone but its still got some uses.Do people still use the s3????
I believe it's called "bluesnarfing", which is the interception(theft) of information transmitted by a Bluetooth device. Think that's why it's very important to have two factor authentication login wherever you can, especially when using a wireless keyboard. In case some undesirable third-party bluesnarfs your login credentials.
Bluetooth is usually only a few metres range. But if you have the right kit, it can be sniffed from miles away.
Like my little 2.4GHz rig with dual high-gain yagi antennas.
