S7 software Issue
just because A phone is rommed or rooted does not make the phone anymore less subject to getting virus or being unsafe. it all falls back on the users actions is what causes you to get viruses just a 1 simple click on a link out on google site can do it all to where you would have been more that happy to have had your phone rooted and completely backed up and saved safely on your computer and pick up where you left off at. just thought to maybe to toss that out there
I have been a member of this android forum every since they first loaded their first site.
Call Blocker?
This. I've never installed anything outside PS, but have heard of trouble doing so. Were I to install from a 3rd party, is this "warning" a one time deal on install or every time I use the app? I have "Lookout", will that throw a flag each time it runs? I get bugged pretty easily by BS like this and would rather avoid it (and avoid smashing said phone).
Russ
It is a setting, called Allow Untrusted Sources or similar.
If you leave this setting on, then the warning is a one time thing.
If you turn the setting off, then yes, you will get the nag screen again.
And Google will also occasionally pester you to turn on their 'app scan security whatchamacallit' BS.
I always decline.
Google is the number two purveyor of malware.
I know damn well that it is just going to flag anything that I installed from anything not Google. Maybe not. I really don't care what Google thinks about my apps. I don't want their opinions, if I did I would ask them. Each nag message makes that even less likely, hahaha!
I don't trust Google any more than I could throw them.
UpToDown is the second largest appstore second only to Google- and UpToDown does not appear in a list of the top 5 providers of malware.
Google is number two, second only to a shady appstore that provides cracked and hacked apps.
UpToDown is based in Spain, I believe, just for some info.
I have used UpToDown extensively, and can help you if you have any issues or questions about it.
I know the UI is not what you are used to, and it takes time (it did for me, too!) to adjust.
Right now, we are jyst dealing with this one app, so let's see how it goes.
You did say that you have it on one device, correct?
You want to find the version number of the app.
If you have the version that you like, then that is the version number to look for.
If it was updated and you don't like the new version, then you want ghe previous version.
The numbers between apps on the app stores usually match, but can be different.
We just need somewhere to start.
Also, keep in mind that updating an app is easy, and you don't usually lose any of the app's data.
But if you want an earlier version, the the newer version must be uninstalled, and all that app's data will be gone.
This only affects that one app, and only if you are 'downgrading' instead of updating.
If I remember correctly, you just want to put this app onto a device that does not have it, correct?
If this is true, then no worries, it can just be installed without an issue.
Voice to Text Sluggish
My phone uses the google text to speech engine. It is not related to the speech to text engine by the looks of it. I disabled this app and it made no difference to the voice to text performance. I also uninstalled it and same, no difference. Contrary to the comments on the play store that some other people think that it is related to voice to text, that does not appear to be the case. It's still a mistery to which app / engine drives the voice to text. As I noted, when I disable the automatic mode for google voice typing, then it defaults to the google voice engine for all apps. And it seems to work fine at interpreting and speed, otherwise it appears there is a different engine when this mode is enabled which is the default and is simpler. ??
Accessories Unboxing ALL the Galaxy S20 Plus Accessories (ok, not all)
Nice set of goodies you've got there. The Samsung inductive charger piques my interest. I've not seen it before. I have an older Samsung EP-N5100TBEGUS that is rated for fast charging but I have no idea how fast. The advertising speaks of compatible Sammy 8 and 9 devices. I don't really need to charge faster but I could step up my game and take my old charger to the cabin. Looking forward to your review on it as well as the car mount / charger. My current car mount is just that... at nice mount with zero charging.
Question. Should I get a new phone or not?
My Moto Z² Force is only 10 months old [because it was a new replacement for a defective one]. I love mine, and have no intention of ditching it any time soon. But I'm not you!
I always buy my phones directly from Motorola, so they're already paid for and that isn't a consideration. If I had the 'free upgrade' option, but it was for a not-very-new model, I'm not sure what I'd do. :thinking: I guess it would depend on whether its specs were that much better than my current phone.
And if you do the 'free upgrade' thing through your carrier, does that lock you in to another 2-year contract with them? That's something to factor in. If you're happy with your carrier--its service, its coverage, its support, its cost, etc.--and want to stick with them, being locked in isn't a big problem.
You might try an old, tried-but-true method of deciding: write down the pros and cons of keeping/upgrading. Just make two columns on a piece of paper, one for pros the other for cons. When you're done, see which side is longer and go from there!
thanks I will do that later on, and plenty of reaserch.
[APP][5.0+][PROMO] AppVoice: voices incoming messages from any installed application
Hi All!
It is my new application,
I will be glad to receive any feedback!
The AppVoice application voices incoming messages from any installed applications, including messengers.
The user himself decides which rules of speaking to add.
The application can be useful for busy people who need to keep their hands free.
Yes, the application can voice notification messages from popular messengers like WhatsApp, Telegram.. etc, SMS or e-mail clients!
Google Play: https://play.google.com/store/apps/details?id=com.bicubictwice.appvoice
[PROMO CODES]
HJL6J6E1ZTX9VT7UNFY7S31
X9LQRAJ8CM4GVDC73TT7KY6
6VTE5DQA7F5ZKNS0Y7H3SBM
RJDH8VQM0NP8UE5RXKESS1M
NH3QWVNJXMU21FA2JEM1QV5
B1JW8W59ANVVZD2DQGUPYVD
81LX60D1DVCX7USQWYLFPW0
NY45P6BEHFQ3SRV8RY1GDCX
NWT5CK1E9FALM4CJWBXCTSP
4K8NP7JY8TSG71E0XMB4CT4
03TPFM8E86CBEEA78YXGRUQ
93FJZQR2YSCNAWT02RRW445
2G3X98ENWKQHZWSLBW76PV6
7260SY30TDJ33NT44D9HCDB
ZAQKWXHA7LE1CD3DC5YU0VX
DPJN8Y4P9L9AM79EPDMXB09
0C7PJ95JQTL1UD394NQGR2C
HVXJ4ZU2HWJ36WS2NM75J7F
JY4504EUEJRYBRB684E5UPG
GU3W3Y4C7C1FEPWA921HT8M
3X6REYA0A9WJXEEFG52GLT3
7M15WK14MUHQ9Y3KPHXLBB6
TR6YYAP8URT431UJTT1404L
0XV1UK2MEMUTJ963BK1MT4T
HZR6R8V7JNQ2W88Z52XJ624
U8X0JGPDDTDM7H0JCUG21R3
L2E594QGYRVLJ2N5DABP6D6
DXGE0W92VKB6YWLWXDDLW0P
RA0R9UK3B5BZWEDTP7RND7B
Security problem
Are you using the same password across more than one site, account, or service? If so, one of the others may have got hacked and your account details leaked.
I have hooked up to public Wi-Fi in the past with cheap pos phones.. were they able to breach my phone then once I hooked up to my personal Wi-Fi at home they were able to breach it?
Just trying to figure these things out! I wish I knew way more than I did!
Custom binary recovery blocked by frp lock note 9
Can you please help my note 9 uk model says Custom binary recovery blocked by frp lock .
https://imgur.com/a/hHhaWZA
Help please
Now my laptop won’t recognize the usb and I can’t get out of this loop. Can you please help how to fix this. I have pressed the buttons wonts take me out from this screen. There’s no way for me to get Odin to recognize my phone. Any solutions I tried down and power don’t work etc
How to add livedata to spinner
How can we use livedata in spinners? I have the following:
LiveData<List<Site>> sites = SiteDatabase.getInstance(this).siteDao().getAllSites();
Spinner spinner = findViewById(R.id.spinnerSites);
**What Goes Here!!*** adapter = new ArrayAdapter<Site>(this, android.R.layout.simple_dropdown_item_1line, sites);
adapter.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
spinner.setAdapter(adapter);
Not sure how to proceed..
Thanks!!
How to open and read .pfx file?
I want to sign a String for my app using a .pfx A1 Certificate but Android Studio isn't reading the file. The iteration below* works on Netbeans just fine but in Android Studio returns false as it was not reading the .pfx file at all.
public String signApp(String input) throws NoSuchAlgorithmException, InvalidKeyException, SignatureException, KeyStoreException, IOException, CertificateException, UnrecoverableEntryException {
String signedString = "";
InputStream certificado;
char[] password = null;
KeyStore keystore = null;
Enumeration<String> aliases;
String alias = "";
//Open the .pfx file
certificado = getClass().getResourceAsStream("imediata.pfx");
password = "1234".toCharArray();
keystore = KeyStore.getInstance("PKCS12");
keystore.load(certificado, password );
//Get the alias
KeyStore.PrivateKeyEntry pkEntry = null;
PrivateKey pk = null;
try {
aliases = keystore.aliases();
while(aliases.hasMoreElements()) { //* problem: it's returning false as it not reading at
// all!!
alias = aliases.nextElement();
if (keystore.isKeyEntry(alias)) {
pkEntry = (KeyStore.PrivateKeyEntry) keystore.getEntry(alias, new
KeyStore.PasswordProtection(password ));
pk = pkEntry.getPrivateKey();
} catch (KeyStoreException e) {
throw new RuntimeException("CATCH", e);
//Keystore
Key key = (PrivateKey) keystore.getKey(alias, password );
java.security.cert.Certificate cert = keystore.getCertificate(alias);
PublicKey publicKey = cert.getPublicKey();
KeyPair kPair = new KeyPair(publicKey, (PrivateKey) key);
byte[] buffer = chave.getBytes();
// Signature
Signature signatureProvider = Signature.getInstance("SHA1withRSA");
signatureProvider.initSign(kPair.getPrivate());
signatureProvider.initSign(pk);
signatureProvider.update(buffer, 0, buffer.length);
byte[] signature = signatureProvider.sign();
signedString = Base64.getEncoder().encodeToString(signature);
return signedString;
Filter
