SpaceMe -Arcade Game [Competition]
Hi, i am wayne, developer of this arcade game.
This game requires you to be mentally present at all times in order to make it to the top.
From now till 25th Jan, there will be a mini competition!
How to take part:
1. Download this game from PlayStore https://play.google.com/store/apps/details?id=com.Wayneren.SpaceMe
2. Have Google Play Games installed to access the leaderboard
3. Login and challenge, the highest scorer will walk away with 0.1 ETH on 25th Jan.
(Please check on the 'Let others see your game activity' in the Google Play Games to upload your score to the leaderboard)
The winner will be revealed on this site, do stay tuned if you are at the top of all time. Contact me through email to verify your Google Play Games name and 0.1 ETH will be posted right away!
https://waynerenchua.wixsite.com/ways/spaceme
Do support this mini-competition, more competition is on the way!
Updated:
As of 25th Jan, no players emerged top. Thank you for supporting.
What's up with all these keyboards?
I'm spending most of the Chinese New Year in Ireland, UK, and Holland. I'm currently in London, go to Amsterdam on Tuesday. So I think I'm safe enough.
Good! I'm glad. That virus is nasty. Last I heard, some ≈25 million people (2 entire cities/regions) had been quarantined--with armed guards preventing their exit. :o
We don't want to see you on the news, Mike, so behave yourself! :D
Latest notifications aren't appearing on top
Are the same notifications always at the top? There are persistent notifications that will always be at the top of the list, with push notifications below them. For example: I use a VPN on my Note 10+ and the VPN connection status is always displayed. If I get a message notification, it will be below the VPN status. Likewise, any time Do Not Disturb is set a persistent notification reminds me of that.
You can adjust the settings to reduce or turn off any notifications you don't want displayed.
no os, bootlooping, unable to access download or recovery mode.
Due to what you just said after explaining about the phone losing connection just at the beginning of the intervention..leads me to the question..what was the last time you change the battery..the battery might be fairly not that old..but maybe when you did the wrong rom..maybe that fried your battery..or a component inside the phone
By flashing the wrong rom, what components would've fried. Just so you know, it worked perfectly fine before i advanced wiped every thing off of the device and i tried to flash the .zip using TWRP not using Odin.
How to stop annoying advertisements?
Yes, but if you look, you have version 18.2 of NewPipe.
As of today, on F-Droid the newest version was 18.1
F-Droid is slow to roll out new updates.
If it doesn't work, try force stop erase data and catche and run the app again.
It is more secure to download from F-Droid than using any app to download its own update. I guess, I've had NewPipe so long I just trust it. Im sure F-Droud will have 18.2 available for download very soon.
Help All media files disappeared - Oneplus 5 - please help
I kbow that this is an older post, but I am hoping that I can put some light where there seems to be very little.
First, if you can, change that timer for the deletion of files.
If you continue doing what you have in the past, it should not need to be active in the first place.
Second, a folder/file called .thumbnails or the like is what is often referred to as a 'junk' file. Thumbnails are the low resolution, tiny pictures that you see when looking through thepics and videos on your device.
These thumbnails greatly speed up the loading time of the menu in apps like Gallery and Video Player.
Generally, lower quality apps like the ones that come with a device use these, and each app can want an entire set of them for each piece of media.
On a lower end device (like mine), this can quickly consume an undesireable amount of memory.
Luckily, I found a Gallery app that is also an editor and a video player- and that does not need thumbnails at all.
Even with thousands of photos and hundreds of videos, the app loads up in mere seconds.
Simple Gallery Pro, by SimpleMobile Tools
Most large app stores have this app.
In my device, thumbnails were stored inside a folder called .thumbnails inside the DCIM folder.
The trick to keep thumbnails from reappearing again and again is to delete the .thumbnail FOLDER and then add a .thumbnail FILE in its place.
This fools the system into thinking that thumbnails exist, so it does not make more.
The period before the folder/file is very important, as this is how the system knows that the media is 'hidden'.
So when attempting this action, be sure to click 'Show Hidden Files' in the File Manager.
There is also a File Manager app made by the same Simple Mobile Tools, called Simple File Manager Pro.
The two work great together.
Also, the Gallery app mentioned above also has a 'recycle bin' that is extra insurance against unwanted deletion of files.
Because the app also allows the viewing of 'hidden' media, you can even look at your thumbnails before deleting them.
Internal Location of Device is not where I am from
I have a Moto g7 power. I bought it unlocked. My problem is that the google play store, and most recently xbox game streaming don't let me access some features available only in America, because my phone does not think im in America. I live in America btw. Whenever I get system updates, not android ones, it shows them in Spanish, or some other language. So my phone internally thinks I'm not from America. And yes I have changed it in time settings and play store. Anybody know how to make my phone think it was manufactured, and from the US?
Do you typically leave 'Location' enabled or disabled? If the latter, try enabling it so your phone's GPS and local cell towers get registered internally. Even if you prefer to leave Location disabled, it might help have your phone get its own locale settings established at least periodically.
Verizon S6 SM620V
Hello Nightangel79.
Thanks for the reply.... kudos.
Hmm haven't tried it yet. Everything was stored on Internal memory.yes I waited for quite some time for the phone to show some life. Then I thought of the soft reset, of which you don't loose any data. Well data gone but phone booted up.i will try Recuva
Thanks
soft reset? the only soft reset is clearing cache. any other kind of reset also wipes data. you can do a factory reset within the phone's settings or you can do a hard reset by powering off and then entering recovery mode (usually some kind of button combo's) and perform a factory reset from there. both will wipe data, however, so i'm not sure what you mean by a soft reset.
and by the way welcome to AF!!!!!!!!!!!!!!!!!!!!!
Help with files by google
message flashed'error unknown couldn't move file', and haven't been able to use that again. And nothing shows in SD card files using the app.
Sounds like your SD card may have died or become corrupted. Can you try reading it in a different device? If it fails there, too...not good.
If you can read it elsewhere, or you simply want to try a different file manager, there are many good ones in the Play Store. One I like is Explorer. It not only connects easily to my LAN, and cloud accounts, but it lets you assign your own icons. (This is not the same as using a different icon pack.) These are my directory icons:
Let us know what happens!
p1ma40 ,problem with a registration into the Google account, Factory Reset Protection?
Hello. I have a problem, maybe it concerns Factory Reset Protection.
I bought a Lenovo p1ma40 phone from a friend, the operating system should have Android 5.1.
The phone required to select a language, then inserting a simcard and then connecting to the Internet on a Wi-Fi network / WLAN from the beginning to power on and start up the startup screen. After a few seconds, he showed a message that the connection to Google servers was unsuccessful or something similar. Inserting or not inserting the simcard did not affect the overall result. All wi-fi networks detected, but none could be connected. I did a hard reset via "wipe data / factory reset". Requires an Internet connection after restarting in the initial setup. Detects Wi-Fi networks, but when you click on one of them to connect immediately displays the message "Couldn't connect to the internet". The Google Account Verification screen will not appear at all.
When switched on via Volume Up + Start it shows, among other things:
MMI Test: Fail
PCBA Test: Fail
Sensor test: fail
Fastboot mode does not appear to work.
I do not have my own PC on which I would have permission to install some software as a network administrator. I have available:
- A working Lenovo phone with Android 6.0
- flash drive
- USB cables
- OTG reduction
Do you know any solution how I can put into operation or test, diagnose, if possible without paid software, eg free software, myself, this phone? Thank you very much for your help.
Quite frankly that sounds like a logic-board{PCBA) failure, or perhaps someone flashed the wrong firmware. It's not FRP causing this.
If it's a hardware failure, that's repair or replacement required, or you'll be buying a new phone. AFAIK to flash firmware on a Lenovo almost certainly requires a PC. For procedure and required software, there might be something here for the Lenovo Vibe P1m.
https://forum.xda-developers.com/lenovo-vibe-p1m/development
GOOGLE PIXEL XL 3 ISN'T SHOWING CONTACT NAMES
I just uninstalled all the updates for messages and all the messages now have the contact name. weird!
Interesting! Sounds like the update borked it! Unfortunately that happens a lot with Google. Will be interesting to see how long it takes for them to push an update to fix the update. Be sure to leave feedback in the messages app and let them know!
Grandfathered UDP Still Going Strong
I have an old grandfathered UDP. Here's my plan:
90.00 unlimited talk and text
50.00 unlimited data plan
30.00 Unlimited Hotspot
With small discounts, I end up paying around 165.00 per month.
I use the hotspot all the time and have not noticed any throttling on either my main phone or on the tethered devices.
I use between 30-50 GB a month.
I held onto mine until about a year ago. Wanted to get family on unlimited so I upgraded. Price didn't change and I never used much more than 20gb anyway.
The newer plan throttle around 22GB. Which phone do you use? Hope they will still have this when 5G is out.
That is an OOOLLDDDDD unlimited plan you simply cannot get anymore. And you can pay like $10 more and they do not throttle until 50gb, and another 10 and you get some additional perks and they do not throttle until 75gb.
$119 for one line, $33 of that goes towards the payment for my pixel 3
Sounds right, I pay $220 with 3 lines, with $30 for my pixel 3xl, and $20 for my pixel 4xl.
Yara FarmWeather: hyperlocal weather for your farm
Hi,
We have a procedure for developers to announce their apps. Read this thread for instructions.
Developer Announcement Procedure
  1. Install the Forums for Android app from Play
  2. Sign in to the forum using the app
  3. Goto the forums tab
  4. Select "My Apps & Games"
  5. Select your app from the list
  6. Tap the green icon in the bottom right to start a new thread
  7. Add a thread title / content and hit the post button (right pointing arrow in the top right of the screen)
  8. Once this is done you can use your PC to create or modify threads in your channel
Once you create the channel using the app I will move your thread to the channel.
If you have any questions, please reply to this message.
Good luck with your app.
-Unforgiven :)
Filter
