Root 1 question before I flash
So this is a good idea in my thoughts because Ive noticed that most problems seem to be linked from stray data left in these folders and most answers to problems are to wipe these folders.
Also after i flash the new rom to reinstall Titanium backup is it best to redownload the root version and then restore the key?
yep exactly. i wipe data, dalvik cache and cache 3x then do the superwipe then flash my rom. i know that is overkill but it works. never had any issues.
Thank you thank you Will be flashing in a few just gota deside on mikg2.5 or the 3d. Again thanks to both of you for the fast replies.
MikG 3D is like MikG 2.5 but with the 3D Carousel and Sense 3.0. MikG 2.5 is sense 2.1 with 3.0 elements. You can't go wrong either way you go though.
I flashed the mikg2.5 its awsome played around a little with it then nandroided back to see how well that works. So because of work ill leave it as is till saturday and then i can get everything the way i want it and deciede witch rom im going to use.
thanks again.
