100% stock Nandroid Backup
CWM 4.0.1.4 Triumph
Stock Recovery
make sure you install the CWM by going into fastboot (vol - and power on) Hook up usb, then drop the recovery.img in the folder on the MOBILE drive.
Extract "Stock Triumph 1980 01 06.00.00.34.7z" to /sdcard/clockworkmod/backup/ Boot into CWM and look for mounts. First format system, data, cache, and under advanced format dalvik cache, then select "backup and restore" and under the restore options select the Stock_Triumph_1980-01-06.00.00.34 folder, and it will restore a never powered on backup of the stock rom.
CWM 4.0.1.4 Triumph
Stock Recovery
i was installing an app (not sure if i want to mention the name of the hacked app here) and it wouldn't go through *stucked at progress installation bar so i just backed out of it/closed it. but when i powered it off then on, phone got hanged up!?! this post was a big help!
thanks!!!
