2 batteries and charger for 30 lul
i dont use the phone much,just calls and a few apps.. other then that it sits in my pocketWas that overnight while you were sleeping
Have you considered diet and exercise?Oh. Yeah. I'm an extremely heavy user.
It's the same price elsewhere.Looking at Amazon, I see that there is 1 battery for $18, 1 battery and the charger for $21, or 2 batteries and the charger for $30. Any thoughts about which option would be the best to buy? Is there a better deal elsewhere?
Not sure why the lul2 batteries and charger for 30 lul
Why? Since between 1 Anker and the stock battery I have a spare I can use, what is the advantage of a third battery?
I bought the 3500mah Anker batt which DOES work as advertised.I am not super pleased with the battery life... and I know there are super huge batteries that you can get, but they require a new, bulky battery cover, which means limited aftermarket covers/cases.
I was wondering if anyone had purchased any of the 1900mAh batteries and noticed even a slight difference. I mean... I'm not expecting wonders, but if it proves to be better than the stock battery, I think I will buy one.
True. IIRC leslieAnn pointed out an Innocell(?) dock that had a shim to accomodate extended batts, and likely some 3rd party "universal" car mounts would work as well but you'd still be entirely out of luck as far as cases go.They have docks that dot extended batteries
At least one company sells an extended battery whos cover integrates a case and fits their docks.True. IIRC leslieAnn pointed out an Innocell(?) dock that had a shim to accomodate extended batts, and likely some 3rd party "universal" car mounts would work as well but you'd still be entirely out of luck as far as cases go.
Doesn't help me though as I ordered the OEM dock and car mount kit before I decided to order the 3500mah batt. (The batt just came MUCH faster than the other stuff...)
They are generic Chinese batteries. They will probably only hold as much as the stock battery... If you are lucky and they might last a year.Also I came across this - not sure of quality but the company is an ebay top seller, so at least the company is reputable...
2x 2000mAh Battery+Wall Charger For HTC EVO 3D Sprint | eBay![]()
Maybe it's just me but even for stock battery levels for a year (two) and the wall charger I think $10 is fine. I'm in for one.
