Root 1984kbps!!speedtest.net results after a couple of tweaks
I am also on CTMod3.75......after you enter ##3282# then dial, it should come up with a screen, where you need to enter your MSL !!
Im doing that and its just calling and telling me its an incorrect code or number wtf I feel like an idiot right now.... im on ej06 would that make a diff... just trying to think up a reason it wouldnt give me the msl screen
i tried ##8778# and that worked but i cannot get to the screen shown in the tut to change to 4gv
Being on ej06 ( quite an old base band ) might be the problem. But I don't know. I currently run FF19, but probably will go back to FE16 which works better for me. If I'd be you, I'd Odin the FE16.....
There is a thread "Quick Base Band switching"..... ( gimmi a few minutes, I'll get the link )
EDIT : Quick Baseband Switching
Thanks so much im trying to find a link to the FE16 rootedw/cwm The one in te odin thread says its been removed from mediafire for violation?
actually the only reason im on ej06 is that its the only one i could find a d/l for
Yeah i havent changed anything i can do ##8778# but not ##3282#
Are you using the stock dialer? Any third party dialer will fail.
I'm on ejo6 and works fine for me?!
Not sure if or what you did wrong........ just tried it and it works just fine here !
Ok so I did a factory wipe and it fixed whatever i had effed up tinkering around with settings and I had FF19 on my laptop i found so i ended up odin to that and now have it straightened out i think i had the dial pad tones turned off somehow screwed somethign up im gonna test that tomorrow but thank you for the help and links much obliged!!:smokingsomb:
Finally got this sorted out heres my scores the earlier ones are before changing vocoder to 4gv later ones are set to 4gv with stock boost prl I have never touched it i need to get cdma workshop
edit: wont upload my image i give up going to sleep !!!
BTW i got into the 1600kbps d/l and over 1100kbps u/l on one test with ping @75ms
