My roommate has reported some lag and erratic behavior before during and after making calls. Two other Droid owners I know have no issues with 2.1 but also were not rooted beforehand. I tried to update with rooted 2.0.1. Sholesmod and got stuck in the endless boot cycle. Undoubtedly has to do with being rooted. My brother works at Verizon, also a Droid owner has had no reports from customers regarding bugs in the three days since the update.
I was also having some delay in the gmail sync. It wasn't pushing instantaneously like it used to. I'm not sure why that is. I've checked off the auto-sync and checked it back on. This seemed to help. Like how after the 2.0.1 update, the four soft keys and keyboard didn't light up in dark situations. You had to go in an click the auto-dim on/off for it work again.
LED notifications are gone, except for voicemail and I believe google's messaging client. But Handcent, Touiteur, etc. don't work. I think that the devs have to update their apps.
Haptic feedback is like the sync. You have to go back in, click it off-on and it should work. At least, it worked for me.
Battery has been good for me so far. But I've been toying with it so the device screen has been on a lot.
The main problem that I am experiencing is some notable drop frames from 2D apps. According to some articles, 2D apps are dropping half the frames (60 fps to 30 fps), intermittently. It makes for some really annoying gaming experiences. From what it sounds like, it might just be that the devs need to update their coding, or Moto/VZW needs to release some sort of a patch to bring us back up to 2.0.1 speeds on 2D apps.
Other than those, I haven't played with the device enough to catch all the nuances.
To all you guys experiencing LED notification problems, is your screen on when you got the notification? its normal on 2.1 it no longer blinks your led if its on since it shows on the bar, it only does it when the screen is off/locked.
That's correct. We were not lucky enough to get 5 screens or the cool app drawer like the Nexus One. Sorry...A few questions... I recieved 2.1, yay.
What happened to additional home screens? I still have 3.
What happened to the cool menu button like it is on the nexus one? Mine looks the same.
Are these two features not included in the droid?
I've seen a few in the market.. start there.How do you load/download more live wallpapers?
If it doesn't, there may be something wrong with your proximity sensor. Can you make a test call for me right quick and place your hand over the top portion of the phone while in call and tell me if the screen goes off or not?I just got 2.1 this morning and I'm wondering if the update will fix me muting calls with my face? That, so far, is my biggest problem with my droid. I either mute calls, try to add calls, or put my calls on speaker during the call all the time.
