truelove79
So, I have a question. Is there a ROM out there that is literally the official Eris 2.1 OTA except with root access? If not what is the highest quality ROM that comes close to it? I really want root, but I LOVE the HTC widgets. And what about other ROMs? How do I know which ones are good/popular? And is there a site that shows ratings and/or screenshots for each ROM? Also, I have the 2.1 OTA now (not leak). I assume I can root using the exact same instructions for rooting from 1.5, I think I read that somewhere. I'm good on the whole process of rooting and all that, I just have no idea where the best place is to get ROMs and which ones are good.
Sent from my Eris using Tapatalk
It should go smoothly, but we'll see.
...check out his posts from this post on and see if this helps you out:
I left mine at the default settings for a couple of weeks before I started reading-up on setting the profiles and the temperature limit. I think most folks that really have an temp. issue are overclocking way higher (upper 700s and into the 800s) than me. I wasn't really worried until I watched my phone's temp with system panel while I was charging and saw that it jumped 9 degrees in a few minutes time. In retrospect, this temperature spike is normal while charging and nothing really to worry about, but I do usually take the phone out of the silicone case just to keep it happy. Enjoy!
