Root 2.2.1 CM Floyo v0.20 problem
giobouk
since i updated to 2.2.1 CM Floyo v0.20,i can't hear other party's voice in phonecalls,unless i turn on the speaker.I also lost the ability to record my calls(from both sides without loud speaker).Using allcall recorder(says that my device doesn't support recording other party's voice, although it worked fine at 2.1)
PLEASE HELP !!!
PLEASE HELP !!!
Hi,
Sorry to hear that you have lost the ability to record your calls.
Custom ROMs are just not made to be compatible to all apps.
Why do you need to record your calls? Are you Dick Tracy or Super Spy something? Heh :)
cheers :)
Thanks for your reply.My main problen is not recording the calls.The main problem is that i can't hear the caller from the ear-speaker.Please help
Hi,
I never had this problem before. It is best to re-install.
All I you can do is to use xRecovery to <Factory reset (full wipe)> before installing the ROM and
after install <skip><setup> go to <Settings><Privacy><factory reset>
after that it should be ok.
cheers :)
Didn't work.I think it is a software problem.Is there a command for the system's root?
Thanks again I appreciate
thank you so much i tried Srom-2.3.3GingerbreadX8-V2 but problem not solved
Hi,
Sorry, but I think you got a hardware problem... Go back to Official 2.1.1 and test.
I have been using Srom-2.3.3GingerbreadX8-V2 for the past 4 weeks... everything works.
cheers :)
