its not. You still need to bump charge.
If you Google for an answer to this, you will find that it is an issue on other phones with 2.2 as well. It sounds like a widespread change in behavior from 2.1.
nothing but problems in 2.2. oh what fun.
i've got this same issue, too.
i don't use bluetooth; i never had a grounding flaw; nevre cared much about flash; 720p quality is awful.
i had nothing but problems since upgrading. i factory reset last night, so now i'm going to see if my batt life/temperature is any better, along with seeing if my weather widget works correctly
Yeah I was telling a friend about mine taking along time to charge. I had this phone for an week i came from the pre i think i might be taking this phone back, because the battery life sucks and it takes to long to charge. If there is any way to get around this please post up before i take this THING BACK.Nothing but problems? Bluetooth is now totally Hands-free. Grounding flaw when phone is docked but not plugged in, fixed. Flash 10.1 native. 720p video. etc...etc...
If this is nothing but problems, GIVE ME MORE PROBLEMS! Woo Hoo!
ThanksAfter I installed OTA I had to do a factory reset do to browser issues. Even after that I see the same battery issue. I have the extended battery, had it on the charger at work for almost 5 hours and it was only charged to 45 percent. Weird thing is it also lost it's charge very quickly for about an hour. Within that hour I made a 15 min phone call, a few texts, and surfed the web for 5 mins. It went from 45 percent to 17 percent and then stayed at 17 for over 2 hrs. Put it on the charger when I got home to see what happens when I go through a full cycle.
I think something is definitely running the CPU harder. If you bring up System Panel and look at the CPU cycles, it never gets below 600 or so, and keeps going up to max. On 2.1, about 4 secs after starting System Panel the cycle would drop down to around 200 and stay there unless you scrolled the screen. Also, my phone is running much hotter. I upgraded with update.zip and have not done a system reset. I'm waiting until I finish Alchemy before I wipe everything.It could be something is running the CPU harder than normal, and is therefore eating more of the power during charge...making it take longer.
BFS Changelog
Kernel #2
- BFS Scheduler patched up to BFS 318
- My hacks to enable 'fast battery charging' *LET ME KNOW HOW IT WORKS OUT*
- Your batteries should charge faster now
- Kernel size shrunk
- Tweaks for stability
- Performance increase
I got froyo last night and today I'm just realizing this problem with the slow ass battery charging. My Incredible used to charge very fast and now it's crawling!
For as fast as the battery drains, taking the phone 4 or 5 hours to fully charge is not acceptable...Now our phones are REALLY going to be living on the charger.
I want to go back to 2.1
