DeepBlueMyst
Alright I have tried doing this without having to sign up and ask, but alas I have tried over the course of last night and most of today trying to get this work that I have a headache now.
Long story short, I have been trying to get 2.2 onto my HTC Hero and while I thought I was doing good with flashing and rooting it. As I tried to install it. The system either A. Aborted the process or B. Started to go through but stayed on the white HTC logo screen [when first powering up] for far to long for me to think it was working. The latter happened when using a different rom not here, so I rolled back.
The one that I have desperately been trying to use is that Elelinux which is the one that gives me the installation abortion message as well. On the site it says to use the installer wizard or wizard rather for installation, but I'm not sure if that's a problem I need to download since it's in zip? So far I've been doing this all from recovery and haven't had any luck on this so so any help would be appreciated
Long story short, I have been trying to get 2.2 onto my HTC Hero and while I thought I was doing good with flashing and rooting it. As I tried to install it. The system either A. Aborted the process or B. Started to go through but stayed on the white HTC logo screen [when first powering up] for far to long for me to think it was working. The latter happened when using a different rom not here, so I rolled back. The one that I have desperately been trying to use is that Elelinux which is the one that gives me the installation abortion message as well. On the site it says to use the installer wizard or wizard rather for installation, but I'm not sure if that's a problem I need to download since it's in zip? So far I've been doing this all from recovery and haven't had any luck on this so so any help would be appreciated
