Rockaholic
I ran the 2.2 SBF and all it did was remove my root! Is this all it was supposed to do?
No, but I re-rooted with Visionary so is it too late?Try a factory reset....is super user still there?
flashing the sbf does not erase data. after doing the sbf you need to do a factory reset to clear it. or do it before hand if you can get into the stock recovery.![]()
Also, do you ned to unroot before yo flash with SBF 2.2 or does flashing take care of this?
