Root 2.2 Stock Image Upgrade Help
MikeAce00
I'm stuck...
2.1, rooted via universal androot, Koush Bootstrap, ROM Manager.
I've flashed the newest clockwork mod in ROM Manager. Errors downloading any previous versions.
Download and install Stock 2.2 Image
And this is where I get stuck.
"replacing stock recovery with clockwork recovery"... then back to main recovery page. No change to phone.
Did I miss a step?
Please Help
Our I get this error, well something similar, I can't remember the exact string
"can't open tmp/recovery.log"
Running 1.0.0.3 Droid x boot strapper
It looks like there are no updates in the market. Is this the most current one?
The attached picture is the error I'm getting...
Plus when I go back to ROM Mananger it says I need Root access. I've rooted successfully with DroidXRoot (1-Click Root) and also the Universal Androot and neither has made a difference.
I also use wireless tether and drocap to confirm root.
Not sure why I am getting stuck. I have downloaded terminal emulator and also adb on my computer but I haven't messed with either yet because it intimidates me (yeah I'm new to this).
I was under the impression the adb or terminal emulator work isn't needed to upgrade via Rom Manager Stock Image.
Any Ideas?
I had the same issue, I am going to assume your phone is plugged in. Unplug the phone and then pop battery out and back in, then power on your phone.
Unplugged...
I popped the battery a few times but that didn't seem to do anything but boot back to 2.1 update 1 (Actually i removed the battery because I didn't know to use the volume rocker and camera button for controls in recovery mode.)
I removed some bloatware early on but only some of the basic that seemed to be safe for deletion. Could this be the issue...
I'd really like to move on from here and try the custom roms and themes...
Thanks Fab! Worked like a champ. Running froyo fly x now. Not even sure what's next but I'm super glad to have gotten to this point. Thank you thank you!
Mike
