2 launchers??
Bren S.
Android Expert
Hi all
I am currently using adw ex as my launcher...but I'd like to try out go launcher.
My question is can I keep adw on my phone while I try out go launcher or will that cause issues?
Thanks
Yes you can bren :D you can even but if you hit the home button a home launcher choice will pop up unless you choose a default launcher
Check out HomeSmack its what i use and will fit your needs perfect.I run two different launchers one for my personal and every day use that's the one i use most,and the second one for my small part time Real-estate business and Rental properties.Never mix Business with Pleasure.
Two launchers are just fine. I have done that since day one having an android rooted and modded. It comes in pretty handy when you get bored with what you have. You can quickly switch without zippin something new and then having to reinstall your gmail account. It's very handy. Besides.. We definitely have the space on our phones for two Launchers. So feel free to play around if you want. :)
No need to be rooted I also run two and have been since December,anyone interested I highly recomend the mentioned above app Homesmack
