cammykool
Android Expert
1 (i asked this with no response) is there any 1.6 like launchers because ive used a g1 on 1.6 and its so simple and eaisy to use i wanna give it a try (im on BACKside)
and is it safe to change the PRL on the phone so it can roam? ive seen some tutoriols scattered on the interwebs taking the PRL froma optimus S and placing it in the V they said if anything it will give you better connections to sprints network
so is it somtyhing i should look into doing?
thanks now for an awnser to my first question
