kninetimmy
hi all knine here i was reading xda and there seems to ba a fairy simple way ( so it seems ) im goin to attempt this. i might need some help bc i dont know were to get certian things.
Things i need to do:
1. Dump your current working boot.img
2. Unpack it
3. Uncompress boot.img-ramdisk.gz
4. ADD the dnsproxy line in init.rc for netd daemon service
Code:
service netd /system/bin/netd
socket netd stream 0660 root system
socket dnsproxyd stream 0660 root inet <----
5. Recompress edited ramdisk
6.Create your new boot.img
Swap the boot.img in the update.zip and it should work. If u have an instruction error(0) while flashing you'll have to change the updater binary in META-INF/ for one that is compiled for your ARM version.
That was for SDK preview, I had to do alot of modifications with the full SDK. The idea is still the same tho, compare the SDK ramdisk with yours and edits
i think this would be really cool any one wanna help?
-Knine
2. Unpack it
Code:
-Knine
