Root 3d effect for dock menu
download, from the market, a system app remover, or use adb. (A system app remover is easier, that's what I use.) Rom toolbox is the one that I use. In the app is an option under app manager, that allows you to uninstall system apps. After you download the launcher you want and have it up and running, go into rom toolbox, or whatever you are using and uninstall the old launcher, to save memory. Now you don't have to uninstall the old launcher at all, just go to the play store and search for a "launcher" than download the one you want, this would be easiest for you.
I've never used anything to remove stock apps, seems the rom dev's got it on lock down to me
If you do not like the idea of un-installing the launcher after you install the new launcher from the Market the first time you hit the home button after the installation it will ask you what launcher you would like to be the default. Can also use an App like Titainium to freeze the old launcher but it is not necessary.
