nomonkeynodeal
I was just experimenting with various .prls, so I was using the stock rom. I performed a speed test in stock, then went back to my CM7 install and tested again only to find that I'm getting half the bandwidth. I guess there is something going on with my CM7 settings/install but I'm not sure what I should check. Not having any luck with searches. Any ideas?
Issac, if you see this, what has been the best .prl for you in Dallas?
