View cthalo thread and download ctmod flash my update on top the follow the advice given in the link in the op. Or you can access ##data# from your dialer but you will need your msl number to access edit functions. Another one is copy the 3g build prop tweak which can be obtained by flashing alien kernel or just copying the tweak manually from the build prop into yours.
