Help 3G network problem?
I need help! I bought my Google Nexus S GT-i9023 and I didn't know that the carriers in my country were only supported (3G) either by 850 or 1900. The nexus s doesn't have no support for those...
What do you recommend me to do?
Is there a way to change that? like changing something in the phone so it can accept 850 or 1900?
Please help! i'm about to cry!!
It's not possible to change that unless you get a new device. The model you have will only support 2G on your network. So i would suggest you return it if you can, and order a new one from Negri which will have the correct bands for 3G on your network. Here is the link for the white version but they also have it in black.
Samsung Google Nexus S i9020A 850/1900 3G (Unlocked) (White)
