Most likely not. Only the low end phones like the Replenish might have slightly slower speeds on 3G. Unlike 4G, 3G speeds vary quite a bit depending on what time of the day you try and use it. It's typically at it's fastest at late night when not as much people are using it. 4G is a little more consistent but more sensitive to signal loss. Example, being inside a house has a bigger impact on signal then it does on 3G.
