Root 3G turbocharger / supercharged V6
gonowhere
Any opinions out there on these? Is it worth the effort? Do you have to run the script every time you flash a new rom?
i have not tried the 3g one but the supercharger is pretty cool. the difference is slight but it does seem to make the roms that you are on a little more smoother. give it a try and let us know what you think.
Reading it now, seems worth a try. Question though, what would constitute RAM scripts or tweaks and ram mgr apps? I know i don't run any task killers.
Basically, any other tweaks such as v6 supercharger or the Car-O-Dope tweaks. You dont want to install one set of tweaks when theres another one in place already.
What about flashing the mike e) 0 tweaks and uninvisible tweaks at the same time,. As well as running v6... Should I be getting rid of all 3 in favor of one kick as tweak? And if so, what do you recommend?
I've never used anything but the V6 Turbocharger scripts. They work great for me.
If you have anything else running, I would either:
Use what you've got now, if it ain't broke ;)
Or undo your current tweaks and try another one out.
You should only run one set of scripts or tweaks at one time.
It is a tweak but for something different. You'll be cool keeping apps2sd and running one of the ram scripts. :)
Ok, so i can keep that one.
I'm not currently running Supercharger or any other ram scripts, just a few tweaks it looks like. But I would like to try the 3-1 script mentioned above and I don't want to delete anything uneccessary, at the same time I do have to clear the path properly.
