If it was on your Homescreen and you haven't uninstalled it, it should still be on your phone. Long press the screen and add either a Widget or an Application, and look for it in the lists. It will be a switch/toggle for 3G or 3G/2G, or something like that.
Cant you just hold down the power button and turn it on/off from that menu?
I am guessing you are using Sense so its probably +>Widget>Settings>Mobile Network you are looking for.
Am I right?
Steve
long press>add widget> settings>tthere is an arrow at the side of the settings widget which brings a drop down list they are all in there
long press on a blank part of your homepage. then select widgets, then to the right of the settings option there is an arrow, click that and select the option you want a shortcut for. done.
Whats the name of the widget .... tht when you press it it turns your 3g on, its got a small picture of a globe on the widget...
