are you s on or off is your bootloader unlocked...lots of questions read the newbie rooting sticky at the top, its not exactly the easiest to root/recovery, but it works.
How do you install TWRP2?
Download goo manager from the market. You can install it from there.
I installed Goo manager but I'm not too sure what my next step is. Do I boot into recovery? which will take me into 4ext.
I just did this. It is painless.
- Open GooManager
- Hit Menu softkey
- Select "Install OpenRecoveryScript"
- Once it is done, boot into recovery and see TWRP2
I immediately made a backup with it because I am not sure if it is compatible with my backups from 4EXT.
- Open GooManager
- Hit Menu softkey
Neither are compatible. unfortunately. I lost my twrp2 stock backup when i swapped to 4ext to test it out.
i know this. i made a full nandroid backup then installed 4ext and the twrp2 backup suddenly disappeared.TWRP2 and 4EXT should be in 2 different folders.
Weird. Mine never did that. However, my back ups for 4EXT are saving in my CWM folder :/
I believe you only need an unlocked bootloader.i assume you need s-off to install twrp 2 via goomanager right?
ill try it when im finished flashing mob 1.02
