Help 4g problems
kiroshi23
i live in New York and was thinking if any of you were having the same problem i have. on my connect i got 3mb,4mb no problem even 5mb. but for the last days i cant even stay at 2mb. is there something going on with metro or is it my phone:(
The play store always downloads new updates , So does Metro Extras and most of that bloatware , Also if you run any apps like facebook or something and it is always syncing then you might need to move your apps to a SD card ($10 for a 8GB Micro SD Card at any local target!)
-Mike
"The Samsung Galaxy Nexus , Only $200 off contract for a limited time only , Only in select stores , Check online for more details , The full Android 4.1 Jellybean experience with a great Android smartphone from Google , The creators of the Android platform*"
(* = Only applies with the $80 plan known as Unlimited Talk and Text and 2GB of High Speed 4G data , Then throttled back to standard 2G/3G depending on area)
I'm in Detroit and always have good service but the past few days my service has been pretty poor. I knw they just switched the prl so I'm sure it will get better and wrk itself out within the nxt couple of days. So in short, yes I think metro is having some issues around our area.
Metro is having issues with towers , also metro speeds down service when a update is coming (Happens with most carriers) Ussually means better speed is coming or something big is about to happen....
-Mike from Verizon Wireless at peabody , MA
"Get the Galaxy Nexus from Verizon only for $159 , Only in select stores , Check online for more details , The power of jellybeans , Delicious at the touch!"
Yes i'm in NYC and noticed the slower speeds.
Funny thing is my upload is
a little over 3mb and my download is right around 2mb.
Been like this for several days now.
MetroPCS upload is allmost always faster than download , Always when I had my LG Connect , I can't wait until friday to get the LG Motion , I might die waiting!
I'm in the bay area and when I changed my prl to 3031 my connection was less stable. I stream videos alot so a constant connection is more important to me than speed. Anything above 150kbs is good with me.
I hope so. I've noticed that even my throttled 4G speed is unbearable... I hope MPCS will update soon!
