LDrifta
No Stranger 2 Danger
ill try it, but when i used the anycut method to manually select, i just got the no smoking sign for 4g only, it seems as if it just cannot search for a signal, but the phone knows it can use 4g lolThis may be the same thing as AnyCut, but did you try the LTE On/Off app? It should be set to "CDMA/LTE Auto" or something like that. You have to reboot to make it stick.
