Root 4G turns on for itself.
lornaevo
I'm running the latest fresh rom and when I turn off 4G and reboot it turns on for itself. Can anyone help?
Mine did that when I had "Power Control Plus" installed. Got rid of it and replaced it with Switch Pro. Haven't had a problem since.
You might also try updating your profile. Especially if you updated your radios or your radios were updated in the installation of the ROM. From you home screen hit Menu/Settings/System updates/ update profile. While your there you might as well do the PRL unless you already did and you are running the latest which i believe to be 60674.
It wont hurt anything to try updating the profile and the PRL. Avoid the Firmware and HTC software updates with root.
I had the same issue when running the last two versions of Fresh. 4g would auto turn on at every boot.
Never found the cause. Now running Myn's and 4g doesn't turn itself on anymore.
