Skitzo6
Member
Which one do I install thanks@Skitzo6 flash this http://forum.xda-developers.com/android/software/viperaudio-viperatmos-3-8-sq-driver-t3289075 .. Improves sound all around
http://system-on-a-chip.specout.com/l/440/Qualcomm-Snapdragon-410-MSM8916From what I gather it supports both armv7 or armv8 but no oem has made it armv8, though I could definitely be wrong
http://forum.xda-developers.com/attachment.php?attachmentid=3610646&d=1452825193 don't forget to thank guitardedhero for his work you will have 2 apps Dolby Atmos and viper 4 android also if you want more bang in your sound https://drive.google.com/file/d/0B1NiqiNsGvRxVk40eHpHZ0otMlk/view?usp=docslist_api dont forget to thank pdesire for his amazing job IMPORTANT FLASH THE SECOND MOD FIRST THEN FLASH VIPER ATMOS OR VIPER ATMOS WILL LOSE EFFECTWhich one do I install thanks
The Leon is natively arm7 32bit.http://system-on-a-chip.specout.com/l/440/Qualcomm-Snapdragon-410-MSM8916
The more I read the more I think that it is just what you described.
The chip supports both, but the kernel was made for 32bit, hence v7. Marshmallow is supposedly natively supporting 64bit (though I don't know what benefit that would have for the Leon), so I wonder if the kernel for the stylo on MM sees the chipset as v8.
Stylo and Leon both use the Snapdragon 410 which is a 64 bit processor but it can run 32 bit as well. The code for 64 bit is in the stock kernel source but LG decided not to use it and went with 32 bit. This is not to save wear and tear on the processor though as the processor can natively run both so that is really not a issue. What is an issue is building for 64 bit as I do not think they have incorperated full 64 bit support into the stock kernel source. Which to me sucks because it is not taking full advantage of the capabilities of the device.The Leon is natively arm7 32bit.
We'd need a system overhaul and a brandspanking new kernel just to interpret 64bit instructions.
My main worry is that since our CPU is arm7, would it lead to extra wear and tear if we converted to 64bit.
The top link for xda didnt work for me. Takes me to a page that says it has been moved or removed.http://forum.xda-developers.com/attachment.php?attachmentid=3610646&d=1452825193 don't forget to thank guitardedhero for his work you will have 2 apps Dolby Atmos and viper 4 android also if you want more bang in your sound https://drive.google.com/file/d/0B1NiqiNsGvRxVk40eHpHZ0otMlk/view?usp=docslist_api dont forget to thank pdesire for his amazing job IMPORTANT FLASH THE SECOND MOD FIRST THEN FLASH VIPER ATMOS OR VIPER ATMOS WILL LOSE EFFECT
Yeah he re uploaded it 3 times last night here's the thread http://forum.xda-developers.com/android/software/viperaudio-viperatmos-3-8-sq-driver-t3289075 its in the attachments its the viper|Atmos 4.2 huawei beats edition don't forget to give thanks for there workThe top link for xda didnt work for me. Takes me to a page that says it has been moved or removed.
Cool thing about it is it survives dirty flashesYeah he re uploaded it 3 times last night here's the thread http://forum.xda-developers.com/android/software/viperaudio-viperatmos-3-8-sq-driver-t3289075 its in the attachments its the viper|Atmos 4.2 huawei beats edition don't forget to give thanks for there work
He put new versions out I just provided the thread good looking out tho@Jack Mickey here you go make sure and flash desire first then viper second
New ones or the same as I got??He put new versions out I just provided the thread good looking out thobtw no need to flash r6.5 its included in the mod and is fully optimized for compatibility
4.1.1 to 4.2New ones or the same as I got??
Thanks guys. Outta curiosity, can these be flashed on cm12.1?@Jack Mickey here you go make sure and flash desire first then viper second don't flash last file uploaded a wrong one
Not sure friendThanks guys. Outta curiosity, can these be flashed on cm12.1?
No XenonHD is not based off of CM. It is highly based off of AOSP. In fact we pull very little from CM as possible. Basing your ROM off of Cyanogenmod is not a good idea anymore. CM is constantly making changes and if you do not keep up with them it will break your build. For example in Android 6.0/CM 13 the brillant devs with Cyanogenmode decided to totally remove vendor/qcom/display-frameworks from source for no understandable reason. This one dicission had all of us with TeamHorizion scrambling to figure out how to fix our build. And like I said we still do not understand why the repo was removed. So if you are gonna base your ROM off CM you should just track all your repos from them. We do not we have our own frameworks repos that we maintain as well as a large majority of repos in the XenonHD source. I give credit to CM as they do a lot of good in the Android community. But CM is making a lot of changes to Android that is not necessary and are only to make CM look good.yea this is based on cm so shouldnt have a problem. loving the rom but switched back to stock to be able to record video in snapchat and facebook messenger.
Change the quality in settingsCan someone tell me when the camera recording build comes out cuz I'm tired of using the app to record vids it doesn't look as good as it does with the regular camera app thnx
Frankly I don't even care about the camera. Coming from a 3+ yr old lumia 920, this camera is a piece of garbage, and I die a little inside every time I try to take a picture.The recording is stuck on 480p and in pretty sure it goes to 1080p or 720p at least right?
Yeah its awesome thinking of making a thread for all compatible soundmodsAbsolutely phenomenal! Made a $20 set of headphones sound like a pair of $100 headphones.
