Pikagunmike2
i checked its camera.msm8916.so
Did you do a wipe when you flashed?i checked its camera.msm8916.so
Just read back a little in the thread. I gave some set up info in some of my posts.actually can someone point me in the direction of learning how to make a rom so i could help too
Yeah I know, but the I am thinking the camcorder may be because of some missing commits in kernel and some missing init scripts. When I am done adding everything today I plan to try and build cm 13 and make another build of XenonHD 5.1.1 to see if the additions I made fixed it.I can verify that camcorder doesn't work on 12.1 9/06 build.
niceYeah I know, but the I am thinking the camcorder may be because of some missing commits in kernel and some missing init scripts. When I am done adding everything today I plan to try and build cm 13 and make another build of XenonHD 5.1.1 to see if the additions I made fixed it.
it works on the 05 build i changed the name of file and it wirked video to just had to save to external onlyI can verify that camcorder doesn't work on 12.1 9/06 build.
On windows 10 XCDownlod this script and run it. It will install everything. But you have to be on linux https://drive.google.com/file/d/0B32Uh5DCLsFxeTg5a096UW1zSVk/view?usp=docslist_api
You need to use linux. You can set up a VM and do it if you want ou set up linux running from a external hard drive like I have on my Chromebook.On windows 10 XC
