Jetster220
Member
Has anyone else had a issue with there phone saying it only has signal 50% of the time and also network location not working while running the latest build of Bugless Beat .2.1?
Switching to ariplane mode and then back seems to fix this, but you have to do it every time you reboot.
Before I noticed it I never noticed missing calls, txt, data or anything like that, so I don't know how "accurate" the time without signal acutally is.
How do you know you are not connected to the network? I do not think I have had this problem...is it losing 3G? or both 3G and 1x?
) the time without signal measures how much time your phone spends searching for service, so you would see a drop in bars down to 0 and no 3G or 1G... This actually happens to me at work because my building eats cell phone signals for lunch, however it should never be 50% if it is that high then you more then likely have a radio problem...I've had it on all of the 2.2 roms I have used... From my understanding this is a code issue with Google...
