Netflix rolled out a marshmallow update on the 18th I believe. Some ppl had to uninstall and re install. But it should work. It's working fine here.Netflix isn't working for me. Video plays for about 5 seconds then freezes but sound continues. So far this is the only app not working for me on 6.0.
I just received a 2.2mb OTA update this evening. New build is MRA58U.
The new factory image is up as well but I took the OTA. I wasn't sure if it would work with the boot loader being unlocked but it did.
Mine keeps failing on the 2.2 meg update.
6.0.1, no issues to speak of here. It's a couple yrs old, and still the best bang for your buck. Either go for it or spend a ton of money on something else. If you want a solid 7 inch tablet, this is it.I am thinking about getting this tablet. Have there been any more OTA updates for Marshmallow that solved these issues?
The issue I reported above about occasional freezing and rebooting hasn't occurred with 6.0.1. It's been rock solid. I get between 8 to 10 hours of screen time which is back to what I got with Kitkat and several days of standby time with wifi left on. If you can get it for a good price the Nexus 7 2013 is still a great tablet!
Might be missing a security update or 2 (or 70) as well. Lol. But that's the beauty of Android, choice! Enjoy what you love, the way you want.after a bunch of video issues, rotation issues, touch screen issues, I have reverted to 4.3. Damn if video doesn't work better, no more touch issues, no more rotation issues. Doesn't have system level chrome casting, that is the only negative I see...
