You might check your gps if you have it... I had a major issue with mine when I first got my Droid. I put on a widget called "power control" (came standard on my droid) and it gives a button with a green light for any running wireless process. I went from getting like 9 hours of my phone doing nothing to now a couple days.. worth a shotWhat is wrong with my phone??
So are you saying that using the widget solved the problem, or removing the widget
I uninstalled the PowerPanel widget and instantly got 50% more Ram memory. I use individual widgets for brightness, airplane mode and bluetooth that I got free from the mkt. Seems faster. I'm still amazed that there are no correlations between all these Ally phones. Hope it flattens out in the future so we will know what the hell we're doing.There is a power control widget that comes on all Android devices. Put it on your screen if its not already there by default and it'll let you turn off everything that on.
When your Android system is taking up a lot of space, as was stated in the initial post, does it make your phone die faster? Or does is hog battery?
