I cannot find a bug in the following application for Android Studio.
We have a set of players
{1,...,n} and a valuation from the set of all subsets to
{0,1}. The apllication is supposed to read numbers labeled with binary strings of length n
corresponding to coalitions S (1 indicates that this player is in S).
And then it should compute how many S have the property that v(S)=1 and v(S-{i})=0 for all
players i in {1,...,n}. I have this code but it has a bug in it.
00=v({0,0})=0
01=v({0,1})=0
10=v({1,0})=0
11=v({1,1})=1
yields 0 instead of 1 (corresponding to {1,1}). The number of all such S for all 's togeather is called "swingove" in the code.
It should be swingove=1, but the app gives swingove=0. Below I attach MainActivity.java i aktivyty_Main.xml.
To make clear the flow of the application, button4 increases by 1 the number of coalitions (subsets of {1,...,n})
button2 generates the editText areas shap is the result for the shapley value (not ineteresting now)
and banzhaf which should after "K" print the number swingove.
I will explain any part of the code if necessary.
00=v({0,0})=0
01=v({0,1})=0
10=v({1,0})=0
11=v({1,1})=1
Code:
package com.example.tablelayout6;
import androidx.appcompat.app.AppCompatActivity;
import android.icu.text.MeasureFormat;
import android.os.Bundle;
import android.view.MotionEvent;
import android.view.View;
import androidx.constraintlayout.widget.ConstraintLayout;
import android.widget.Button;
import android.widget.EditText;
import android.widget.RadioButton;
import android.widget.TableRow;
import android.widget.TabWidget;
import android.widget.TextView;
import android.widget.TableLayout;
import android.view.ViewGroup.LayoutParams;
import android.widget.LinearLayout;
import java.lang.StringBuilder;
public class MainActivity extends AppCompatActivity {
public Integer N=0;
public String a="2";
private EditText editText1;
private EditText linear;
private Integer[] hodnoty =new Integer[10];
private String[] koal=new String[10];
private float[] shap=new float[10];
[USER=1021285]@override[/USER]
setContentView(R.layout.activity_main);
public boolean iswinning(Integer J,int ii) {
return true;
public Integer fact (Integer f) {
if (f==0) return 1;
else return f*fact((Integer) (f-1));
//T pocetHracu
public Integer[] stringToArray(String binary) {
Integer[] arrayOfPLayers=new Integer[binary.length()];
for(int i=0;i<binary.length();i++) {
arrayOfPLayers=Integer.parseInt("" + binary.charAt(i));
return arrayOfPLayers;
//N je pocet koalici
public void click5(View view) {
int pocetHracu=Integer.toBinaryString(N-1).length();
Integer[][] koalice=new Integer[N][pocetHracu];
Integer[][] koalice2=new Integer[N][pocetHracu];
Integer[][] koalice3=new Integer[N][pocetHracu];
TextView tv6 = (TextView) findViewById(R.id.textView6);
for (Integer ith=0;ith<N;ith++) {
for(Integer T=0;T<pocetHracu;T++) {
String StringPadded=stf(Integer.toBinaryString(ith),pocetHracu-Integer.toBinaryString(ith).length());
koalice[ith][T]=stringToArray(StringPadded)[T];
koalice2[ith][T]=stringToArray(StringPadded)[T];
koalice3[ith][T]=stringToArray(StringPadded)[T];
float[] shap=new float[pocetHracu];
float[] vyhryKoalici = new float[N];
Integer[] isSwing=new Integer[pocetHracu];
for (int i=0; i<N;i++) {
editText1 = (EditText) findViewById(330+i);
String a=editText1.getText().toString();
float f1 = Float.parseFloat(a);
vyhryKoalici=f1;
Integer[] kolikJeSwingu= new Integer[pocetHracu];
String S="";
Integer jth;
for (int p = 0; p < pocetHracu; p++) {
isSwing[p] =0;
kolikJeSwingu[p]=0;
for (Integer ith = 0; ith < N; ith++) {
int bool = 1;
//vyhryKoalici[ith];
//musis najit jth<N pro ktere koalice3[jth]=S-ith
if (koalice[ith][T] == 1 && vyhryKoalici[ith]==1) {
koalice3[ith][T] = 0;
for (jth = 0; jth < N; jth++) {
for (int k = 0; k < pocetHracu; k++) {
if (k != T && koalice[ith][k] != koalice3[jth][k]) {
bool = 0;
if (vyhryKoalici[jth] == 0 && bool == 1) {
isSwing[T]++;
koalice3[ith][T]=1;
//kolikJeSwingu(Integer TmaSwing, Integer pocetHracu, Integer pocetKoalici,
// Integer[][] koal, Integer[] koalicePriKtereJeSwing, float[] vyhryKoal)
//isSwingBool(Integer kteraKoalice, Integer TmaSwing, Integer pocetHracu, Integer pocetKoalici,
// Integer[][] koal, Integer[] koalicePriKtereJeSwing, float[] vyhryKoal) {
// kolikJeSwingu[T]+=kolikJeSwingu(T, pocetHracu, N,
// koalice, koalice[ith],vyhryKoalici);
if (koalice[ith][T] == 1) {
koalice2[ith][T] = 0;
int bool = 1;
if (k != T && koalice[ith][k] != koalice2[jth][k]) {
bool = 0;
int bool2=0;
koalice2[ith][T] = 1;
if (vyhryKoalici[ith] == 1 && vyhryKoalici[jth] == 0) {
if (koalice[ith][k] != koalice2[jth][k]) {
bool2++;
// if(bool2==1) {
// isSwing[T]++;
Integer t = 0;
t += koalice[ith][p];
// Integer[] isSwing=new Integer[pocetHracu];
if (bool == 1) {
shap[T] += (float) ((float) fact(t - 1) * fact(pocetHracu - t) / (float) (fact(pocetHracu)) * (float) (vyhryKoalici[ith] - vyhryKoalici[jth]));
S+="here";
String T2="";
T2+="banzhaf";
Integer swingove=0;
for(int p=0;p<pocetHracu;p++) {
swingove+=isSwing[p];
String strPokus="banzhaf ";
float[] banzh=new float[pocetHracu];
banzh[p]=(float) isSwing[p]/(float) swingove;
String strPokus2="shap ";
for(int i=0;i<pocetHracu;i++) {
// S+=(" "+String.valueOf(shap));
strPokus2+=String.format("%.2f ",shap);
strPokus+=String.format("%.2f ",banzh);
// tv6.setText(strPokus2+"\n"+strPokus+"\nswing"+isSwing[0]+"swingPrvni:"+isSwing[1]+"\nH"+swingove);
tv6.setText(strPokus2+"\n"+strPokus+"K"+String.valueOf(swingove));
public void click4(View view) {
linear = (EditText) findViewById(R.id.simpleEditText);
if(N==0) {
linear.setText("0");
String a = linear.getText().toString();
N = Integer.parseInt(a);
N++;
linear.setText(N.toString());
public String stf(String a,Integer l) {
if(l==0) { return a; }
l--;
return stf("0"+a,l);
public void click2(View view) {
String col1;
String col2;
// String playerChanged;
TableLayout tl = (TableLayout)findViewById(R.id.tableLayout1);
EditText editText = (EditText)findViewById(R.id.simpleEditText);
TableRow row = new TableRow(this);
TextView tv = new TextView(this);
TextView c = new TextView(this);
//EditText etUserInfoNewValue = (EditText)findViewById(R.id.simpleEditText);
// a = editText.getText().toString();
tv.setId(202);
tv.setText("This is text");
tl.addView(row);
row.addView(tv);
int sf=Integer.toBinaryString(N-1).length();
for (int x = 0; x < N; x++) {
//String.format("%010d",(
String jl=Integer.toBinaryString(x);
String jl2=stf(jl,sf-jl.length());
koal[x]=jl2;
col1 = "(" + x + ")"+jl2;
// col1 = "(" + x + ")"+Integer.toBinaryString(x);
col2 = "1";
//col3 = "(" + x + ") Column 3";
//col4 = "(" + x + ") Column 4";
TableRow newRow = new TableRow(this);
TextView column1 = new TextView(this);
TextView column2 = new TextView(this);
EditText editText1 = new EditText(this);
editText1.setId(330+x);
// String stringAnswer = editText1.getText().toString();
TextView column3 = new TextView(this);
// TextView column4 = new TextView(this);
editText1.setText("0 ");
column1.setText(col1);
column2.setText(col2);
//column3.setText(col3);
//column4.setText(col4);
// column1.setText(stringAnswer);
newRow.addView(column1);
newRow.addView(editText1);
newRow.addView(column3);
// newRow.addView(column4);
tl.addView(newRow, new TableLayout.LayoutParams());
XML
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:android2="http://schemas.android.com/apk/res/android"
android:layout_width="wrap_content"
android:layout_height="fill_parent"
android:layout_columnSpan="12"
android:layout_columnWeight="12"
android:accessibilityLiveRegion="none"
android:eek:rientation="vertical">
<TableLayout
android:id="@+id/tableLayout1"
android:layout_width="fill_parent"
android:layout_height="wrap_content"></TableLayout>
<Button
android:id="@+id/button2"
android:eek:nClick="click2"
android:text="Button2" />
<EditText
android:id="@+id/simpleEditText"
android:layout_centerInParent="true"
android:digits="10"
android:hint="Enter Your Name Here"
android:inputType="text" />
<Button
android:id="@+id/button4"
android:eek:nClick="click4"
android:text="Button4" />
<Button
android:id="@+id/button5"
android:eek:nClick="click5"
android:text="Button5" />
<TextView
android:id="@+id/textView6"
android:text="Shapley1" />
</LinearLayout>
