A call blocker that works?
keegan1014
Im looking for a call blocker and sms blocker that works I dont even want to know that this person tried to call.
Anyone know of one?
If it's just one number and you don't mind doing this:
1. Log into your My Verizon from your computer
2. Click on the Safe Gaurds tab
3. Click the Call & Message blocking tab then go from there
I had to do this on my phone when I changed the number and one person wasn't getting the clue what they didn't know me. lol
Good luck. :)
I have call blocker lite. It does both calls and sms, however the sms appears in your messages briefly before it is auto-deleted.
The only one that works for me is Norton Security.. its on beta and is good for 90 days. It has call blocker,sms blocker and malware scan. Droidblock did work for a little while, but this one is consistent.
I use Norton Security and have for a good six months. It doesnt ring, but shows up as a missed call in your notification window. You can also block texts and it does run security scans.
Haven't seen it mentioned, but I use Mr. Number. It allows any number you chose to be blocked. It also allows you to block any area code which is great for 800 numbers and such. It will also block text messages if you enable it. It includes a free 7 day caller ID and if setup, will prompt you to add any number not in your phone book to your contacts for both texts and calls. You can chose to have calls go directly to voice mail or pick up and hang up. I've been using it for months and have no issues with it at all.
I use Mr. Number too. Works for me.
You can try http://bit.ly/mQVfWp
It blocks calls as well as SMS and it works pretty good. No notification for SMS, it just blocks them and stores them in its own log, calls are also handled nicely and you never hear the phone ring.
