Bully74uk
EDIT2: PEOPLE ARE NOW (AS OF 04/08) REPORTING THAT AFTER DEBRANDING THEY ARE NOT GETTING THE 2.2 UPDATE. IT SEEMS THAT HTC 'MAY' HAVE STOPPED ROLLING IT OUT ! IF SO, AND YOU STILL WANT TO INSTALL 2.2, FOLLOW EVIL GENIUS' LINK ON POST #48 TO MANUALLY INSTALL.
EDIT1: IT SEEMS THAT THIS PROCEDURE WILL NOT WORK IF YOU HAVE UPDATED THE PHONE WITH THE RECENT VODAFONE UPGRADE (1.124 I BELIEVE)
So as expected I got too impatient to wait for Vodafone to officially launch 2.2 so I bit the bullet, debranded the handset and got the update.
Im glad I did as I understand that Vodafone have just rolled out a sneaky update loading the handset with rubbish.
Thought I would share the experience with my fellow Vodafone users including the guide that I used in order to complete the installation.
This turned out to be a very easy process which took around an hour from start to finish inc the 2.2 update and restoring apps etc.
PLEASE READ THIS FULLY BEFORE STARTING THE PROCEDURE
Worked a treat on my handset but as with all these things I can't accept any responsibility for any loss or damage that may occur if you decide to go down the same route that I did.
Also please be aware that debranding your handset may invalidate the warranty should anything go wrong. Im not sure whether its possible once 2.2 has been installed to revert back to the old Vodafone Rom (should the phone need to go back to Vodafone for example) so please bear that in mind.
So, in simple terms I uninstalled the original vodafone Rom (operating system) from the phone and reflashed (re-installed) a generic HTC Rom (one that isn't operator specific). After this install I manually checked for updates on the handset and was prompted to update to Android 2.2. Which of course I did
I re-installed my backed up data and everything's good.
So here's how I did it.
1, I already had a copy of an app called mybackup pro (available in the market) and I used this to make a backup on my Micro SD card and on their internet server of all my data and apps. I think this app has a 30 day trial, if so you can use it for the this process then uninstall without buying it.
2, I then copied the contents of my Micro SD card to a folder on my PC as an extra backup but haven't needed it.
THE UPDATE WILL WIPE ALL DATA FROM THE HANDSET SO MAKE SURE YOU BACK UP.
3, I noted down all the APN settings from the phone as an additional precaution but again didn't need them. MENU - SETTINGS - WIRELESS & NETWORKS - MOBILE NETWORKS - ACCESS POINT NAMES - VODAFONE.
4, I then followed this guide to create a gold card and reflash the handset but with one major difference, I used a different Rom to the one that's linked to on section 1 of the debranding procedure because Id read of people having problems with the one listed:
This is the guide: Debranding / Unlocking an HTC Desire - The giffgaff community
And the Rom I used is this one : RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4. 06.00.02_2_release_126984_signed.exe
Which can be downloaded here (its the very top one labeled 'new bravo Rom'): RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4. 06.00.02_2_release_126984_signed.ex - xda-developers
* I used a separate Micro SD Card to create my Gold Card (mine was a Kingston 2GB card) but the guide explains how to use the one from your desire. If using the same card you must make a copy of it on your PC first as you have to reformat to FAT32.
* Check the requirements at the top of the guide regarding installing HTC sync. I didn't have this installed on my PC prior to the reflash, its in a folder on the SD card that came with your phone so connect that to your PC and install it before starting.
* You only need to do the first 2 sections of the guide 'creating the gold card' and the 'debranding procedure' The last section is about unlocking the phone and isn't relevant for this procedure.
5, When you run the new downloaded Rom it comes up with an installer on your PC, its all pretty straight forward and simply a matter of pressing Next each time.
6, Once the reflash is complete the phone will have rebooted and you will now have a working generic HTC Rom on your phone. It should prompt you to select what Network you are on (in my case Vodafone Post Pay) and then guide you through the start up wizard. At this point leave the gold card in the phone.
7, Make sure your WiFi is set up and switched on on the handset and go check for updates. MENU - SETTINGS - ABOUT PHONE - SYSTEM SOFTWARE UPDATES - CHECK NOW. You should be prompted to upgrade to Android 2.2.
8, Click to download and install the upgrade and Bobs your uncle, you will now have an unbranded Desire running on Vodafone with Android 2.2
YOU CAN NOW REMOVE THE GOLD CARD AND EITHER PUT IN YOUR ORIGINAL SD CARD OR IF YOU USED THE SAME CARD COPY THE DATA BACK TO IT THAT YOU BACKED UP AT THE BEGINNING.
Restoring data and Apps
After the install I had to re-install Mybackup Pro and select 'restore' to re-install all my data and apps.
Some of my apps also showed up in the market under 'downloads' so I could re-install or update from there. Google maps for example required an update to the latest level.
I also had some apps that were stored as APK files on my SD card
To re-install those I simply re-downloaded Astro File manager from the App store, located the Apps through that on the phone and re-installed the APKs.
Easy as that.
Im a complete Android noob and although Ive tinkered with other phones (sort of rooted my old Nokia N95 8GB) I don't have a lot of experience with this type of thing, but to be fair this process wasn't must different to the official upgrade procedure that you had to go through with Nokia !
Hope this helps if you are using a branded phone and wish to debrand in order to get 2.2.
Thanks.
Bully.
Easy as that.
Thanks.
Bully.
