A guide on how I debranded my Vodafone Desire to get 2.2 quicker.
Debranded with a mix of the instructions going about. Had resigned myself to not getting froyo OTA today, however to my pleasant surprise i did, so hasnt been pulled by HTC.
Details:
Previously vodafone branded 1.19 etc without the crapware update obviously.
Upgraded to 1.21 as file in first post has.
Kept gold card in at all times. (Have now switched out to my new 16GB card.)
Any more details just ask and ill get back to you
Just debranded my Vodafone bloatware-ridden handset and got 2.2 OTA update 5 minutes later :)
I'll outline the procedure for those who, like me, have a new Desire with SLCD, 0.83 bootloader and Vofadone firmware 1.24, and would like to have stock firmware instead.
Warning: you will lose all settings and data from your phone, so make a backup.
Standard disclaimer: it worked for me, it may not work for you, I don't take any responsibility, yadda yadda. I will do my best to describe what I did in a clear way, but treat it with a pinch of salt.
Step 1: Root
Root your phone (don't worry, you'll unroot it later) using instructions contained here:
Source: [ROOT] Method for HBOOT 0.83 (SLCD phones) - xda-developers
The description is straightforward so I won't repeat it.
Step 2 (optional): Backup
It's wise to backup your phone while you have the ClockworkMod installed, it could come in handy later.
Source: xda-developers - View Single Post - [ROOT] Method for HBOOT 0.83 (SLCD phones)
- Boot to recovery mode. Steps: 1. power off; 2. power on while pressing volume down button; 3. when you can interact with the phone (it takes a few seconds), choose 'recovery' (use volume keys to navigate and power button to select).
(A hint that was useful to me: in ClockworkMod, you navigate by volume buttons but enter menus by the optical trackball button, not power button.)
- Select 'nandroid' from the menu and perform a backup.
- After the backup has finished, go to 'partitions' submenu and mount the sdcard as a USB drive.
- Now that the SD card is visible as a removable drive, copy everything in the clockworkmod directory to a safe place.
Step 3: Reflash
As you're running 1.24 firmware, normally you wouldn't be able to install generic 1.21 -- RUU installer will not allow you to downgrade version. Hence you need to cheat your phone into thinking it's 1.21 first.
Source: [HOW-TO] Downgrade HBOOT - HTCPedia.com forums , plus my modifications.
- You will need Android SDK. If you don't have it, download it here: http://dl.google.com/android/android-sdk_r06-windows.zip and unpack to your chosen location.
- Download this RUU: http://shipped-roms.com/shipped/Bra...1.00.32U_4.08.00.09_release_137222_signed.exe
(Make sure you get this one; others won't work and will break your phone if you have hboot 0.83 and SLCD screen!)
- Go to Desire mtd0.img creator . Enter CID 11111111 and ROM version 1.21.405.2. Download and save the mtd0.img file for later.
- Download flash_image binary from http://benocharm.lensworks.org/flash_image and save it along with previous file.
- Boot the phone to recovery mode.
- Connect the phone (still in recovery mode) to your PC via USB cable. In ClockworkMod recovery menu, navigate to Partitions and mount /data partition. It takes a while, don't panic, wait until the menu returns.
- Open commandline on your PC. Go to the folder with Android SDK you downloaded earlier. Go to tools subdirectory.
- Do the following in the cmdline:
adb push /[the folder you downloaded it to]/flash_image /data
adb push /[the folder you downloaded it to]/mtd0.img /data
If you're having problems with file paths, just copy both files to the SDK tools subdirectory and push from there.
Then:
adb shell
chmod 755 /data/flash_image
/data/flash_image misc /data/mtd0.img
exit
adb reboot oem-78
Now your phone has been told that it has firmware 1.21 and was rebooted to RUU mode. Leave it as it is and launch the RUU installer you downloaded earlier. Follow the instructions.
If everything went smoothly, you should have a fresh, sparkly, unbranded, unrooted, stock 1.21.405.2 in a few minutes, and OTA upgrade to FroYo should appear soon.
HTH!
Vasquez, many thanks for posting an easy to follow step by step guide
I have 1.24.1661.3 software installed by the OTA update, however I have the 0.80 bootloader, NOT 0.83 ....
Do you know if your guide will work with my phone or can anyone else confirm they have done this with 0.80 bootloader?
hi, brand new to this so please bear with me!
have a voda desire that was initially unbranded however did update with the latest Voda update. have checked my boot number and is listed as 0.80 but running the 1.24 voda update.
which steps do I need to do to remove and then update to 2.2?
many thanks in anticipation
dp
dp
are you sure you have bootloader 0.80?
for those that still have bootloader 0.80
what i did to go from 1.24.1661.3 to 2.09.405.8 is this
-> rooted the phone using unrevoked3 method
-> made a goldcard
-> installed a custom rom from modaco 1.21.xxx.x (it's not possible to go from 1.24.1661.3 to 1.21.405.2)
-> tried to install generic RUU 1.21.405.2 - didn't work ->bootloader error
-> repaired the /misc
-> ran the generic RUU 1.21.405.2 - yey, it worked
-> OTA update to 2.2 was not available, did a manual update
-> enjoy your frozen yogurt
absolutely, when I reboot and hold down the back key, the second line reads as:
HBOOT -0.80.0000
Software Version - 1.24.161.3
I am leaving the country for 10 days tomorrow and want to complete the upgrade before I go and not wait for the voda release... any ideas??
DP
Details:
Going to do exactly this later this week when I have some time (unless Voda pull their finger out!!). Have already created the Goldcard but have 2 simple questions :
- Did you keep the sim card in or leave it out?
- I've read the instructions about what connection mode to use for the Goldcard (sync, mount etc) but what do you use for the 2.1 upgrade. Is it just mount disc?
Thanks
Thanks
I kept the sim in at all times.
I believe i had it on charge only.
Step 1: Root
Step 3: Reflash
Then:
adb shell
exit
adb reboot oem-78
HTH!
Hi,
I have successfully debranded my Vodafone branded HTC Desire to Stock ROM and guess what i got the Froyo update as soon as i rebooted my Phone & connected to my Wifi connection (its better to remove the sim and do the update).
And yes if anyone has got 0.80 bootrom they can use the same procedure used for 0.83 bootrom listed above to unroot, flash and then install Froyo on their HTC Desire.
Any questions anyone can email me on farooq2u@gmail.com and i would be more than happy to help u out.
Again many thanx to vasquez for the great step-by-step guide that works.
Bye
(Let me enjoy my freshly baked Froyo):D:D:D:D:D
HI, err right I`m a COMPLETE NOOB ! with the Android stuff.
I have a Desire on Vodafone contract (Branded with the updates).
I have the Hboot version 0.83... is this ok to use the guide on Page1 for 0.83 ?, or is that what the `Un-revoked 3` is for ??
My brother got his HTC Desire a few week ago and de-branded it yesterday, BUT he didnt have the Voda updates installed and he doesnt know what Hboot he had before he started.
wich is it?
the guide or unrevoked 3 ??
thanks. :)
wich is it?
thanks. :)
'Unbranded' pre-update Voda Desire will have 0.80 Hboot version. That's what mine has
@peakprowler: There's quite a few guides around for those with 1.24 and 0.80 bootloaders, as these are for older and more widespread phones with AMOLED. You will need to use a different root method and a different RUU, probably this one.
Re my post earlier. Update from HTC customer support by email (not phone this time)
Dear Ewan,
You cannot debrand your device as the ROM upgrades on our website require your Serial Number, if you enter your Serial Number into the unbranded ROM download it will not recognise it. This is because we do not downgrade devices, and doing so will void your warranty. Best Regards, HTC
To send a reply to this message or let me know I have successfully answered your question log in to our ContactUs site using your email address and your ticket number *removed*.
Sincerely,
Jennifer
HTC
EDIT: If they check the serial number during updating how come i (and everyone else) were able to update OTA. Shouldnt our serial number have voided that update?
Got a Desire back from Orange, ran with glee to my machine and started to flash, only to find that bootloader 0.83 was now present, stopping my much loved debranding. I've been searching all evening for a solution and some came close.
This guide however, is very straightforward and worked flawlessly for me (Only difference is used a different rom because I still have an AMOLED screen). The push part hadn't worked previously, but your modified method worked a treat.
I made an account just to post this thankyou, my clean 1.21.405.2 rom is updating to Froyo as we speak. Two thumbs up!
Hi everyone
I'm having some trouble debranding my phone.
Got latest HTC Sync installed and created my goldcard. Goldcard is inserted in the phone.
My HBOOT is 0.80 and it's an O2 HTC Desire
Downloaded... RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4.06.00.02_2_release_126984_signed.exe
But what's the process to actually run that .exe?
Phone on, USB debugging, USB connected as HTC Sync?
When I try and run it the installer starts to load then just quits after about 5 seconds, so pretty sure I'm being dense on this stage.
Here's the quote from bully74uk's original post in this thread...
5, When you run the new downloaded Rom it comes up with an installer on your PC, its all pretty straight forward and simply a matter of pressing Next each time.
I don't even get to press a next button, the installer just quits.
Any ideas?
Ok turns out I'm an idiot.
Tried the installer on another computer (the 4th one required for this whole process) and the installer ran and completed successfully.
Then ran the OTA update and now got Froyo on my phone as HTC intended... no more O2 stepping on the hosepipe!
Thanks for the instructions :D
I did everything in the Step 1. But now I cannot boot into Recovery mode. When I try to do that, my screen stucks on O2 logo with(!) a thin light blue vertical line on both sides of the screen and small black bar at the top of the screen. Everything else works (phone boots, etc.)
Note: My phone is O2 UK HTC Desire with Hboot 0.83 and o2 firmware 1.20.207.3. because of the firmware version I assume I don't need to downgrade it, do I?
any help would be much appreciated
Sorry for reopening an older thread but im scratching my head at all the new information to take in regarding android in general.
Two questions (one really :D)
Is it possible to use vasquez step by step guide on a UK branded Orange desire with hboot 0.83.0001 loader and software 1.22.61.1?
If so, could someone please send me a copy of the mtd0.img creator (the link is broken in the tutorial)?
Cheers :)
