malcster
Yes, in the same boat. If anyone knows where the 2.2 ROM can be downloaded it would be much appreciated.
i have the install file still i can upload to megaupload etc tonight if you still need it
Doing a quick google search on the long filename, it came up with.
Hotfile.com: One click file hosting: OTA_Bravo_Froyo_HTC_WWE_2.09.405.8-1.21.405.2_release4dua3bcrut4wrv30.zip
Not sure if it'll work, but its the same size etc, looks like a mirror, However as it's not from the HTC site, i can't really say it's safe.. it probably is, but.. you know.
No it can't - if you have this on your phone it means you should be rooted. Superuser permissions is like the control app for root access. When an app requests root permissions superuser should pop up asking if you want to allow it. It can be set to remember this preference & if you wish to change a permission at a later date it has a list of your current permissions in the app.
You can get rid of it if you flash a non-root rom, but overall now youve got it I wouldnt try to get rid of it![]()
So, Ive come to the conclusion that if I have 0.83 hboot, it is possible to root, however the device will not boot into recovery, meaning I can't install any new roms...so anyone in the same boat as me is pretty much screwed until a new hack is created..
Doesnt work with my branded vodafone
Software:1.24.161.3
HBOOT:0.830001
How did you gain root?
If im completely honest, im not 100% sure, I used unrevoked3, and followed the steps, I thought it failed, but I now have the 'superuser permissions' on my menu, which apparently means im rooted..im a bit of an android noob, so i wouldnt listen to any of my advice to be fair!All i know is, on the current hboot, there isnt much we can do until a crack is found.
Hmmm. Interesting. But I'm under the impression that I cant root due to only buying my desire a couple of days ago, as it has preloaded 0.83 hboot, with all the Vodafone junk on it. I have tried to root, but as far as I'm aware ive been unsuccessful.
Yeah i got the same using unrevoked, got the Superpermissions icon, but phone acts as though its not rooted??? I also tried the 0.92 to 0.80 update from xda developers but get a CID error, is there any good way of testing the goldcard and SU icon to confirm if either are working correctly? Would be annoying to go through this and it be my sdcards
Yeah, my phone seems to be in the same state as yours then, I've not tried to 0.92 to 0.80 update as yet, as I'm pretty sure it wont work, but I might give it a shot. But like I saidm I'm a bit of a noob, i was just told that if I have the superpermissions icon, then I'm rooted, but as you say, the phone isnt acting like its rooted. I'll give the 0.92 to 0.80 update a go and report back if it works.
Hey swoose someone at xda with identical phone bricked when he managed to get it to work so might be worth waiting for more info
@chump_137. Thanks for the quick reply. So currently I'm stuck with a broken version of 2.2. Are you saying start again. ie create a goldcard, reflash the debranded 2.1 rom (can I do that from a broken 2.2) and then update the 2.2 zip from the goldcard?
Thanks a lot for the help
Only thing i thought I'd get is the round battery symbol but I presume thats only available on cooked roms as mines same as always.
You don't have to make another goldcard mate, the one you made is permanent. Just copy the update.zip on to that card. reboot into recovery mode then install the SD/update.zip.
correct. you need to root and rom for that kind of jiggery-pokery....
