Evil Genius
could be. not sure really.
i just re-installed lockbot and set it up again using flan.
ok couple of questions
1, is still still working after the bloatware update (my boot is 80.000)
2, can i do it using a mac?
thanks in advance
anyone?
Can i just confirm that the guide at the start still works? I donloaded all the necessary stuff.... but if the OTA update is no longer available is there any point in going forward with it?
Thanks evil but that link doesnt work...
503 - service not available
Doing a quick google search on the long filename, it came up with.
Hotfile.com: One click file hosting: OTA_Bravo_Froyo_HTC_WWE_2.09.405.8-1.21.405.2_release4dua3bcrut4wrv30.zip
Not sure if it'll work, but its the same size etc, looks like a mirror, However as it's not from the HTC site, i can't really say it's safe.. it probably is, but.. you know.
My software number 1.24.161.3
I get a bootloader error. Is this a solution? Waiting for your help. Thank you.
Thank you for your interest. One solution might be the future?Unfortunatly, This is the Voda "unwanted" update. as far as im aware, you cannot use this method to remove this..
I'm sorry for my english.
to photon00
Yes i had troubles with installing apps, tried to install reboot of OS...
Aparently it's because the apps are requesting to be installed on your sdcard and some bug prevents then from doing so...
so the solution is...
go to...
menu->settings->sd & phone storage->Unmount sd card
install apps
then remount sd card...
there is a app on the market called SDmove that then allows you to move apps to your sd card after installing em.
Thanks for the help gjs585. Unfortunately I still have the problem after doing this. I'm not too confident in my install. If I go into recovery I still see the message regarding the /cache/command/recovery.
I'd like to reinstall again. Doe anyone know of a way I can go back to 2.1 and then update again?
New UnRevoked IMG for HBOOT 0.83 [ROOT] Method for HBOOT 0.83/0.92 (SLCD phones) - xda-developers
Got clockworkrecovery fully working on my branded vodafone
1.24.161.3
HBOOT 0.83
