Root A little help with partitioning sdcard?
I have a 7 gb fat32 and 1gb ext4 partition on my 8 gb sdcard. I want to re-partition it. I use gparted. But the size shows up as 6.35 gb. How do I revert it back to it's original state?
I did..I did..but the space still shows up as 6.35 gb. How do I get rid of the ext4 partition?
In GParted, select the partition you want so its highlighted, I think you then unmount it, then delete it. do the same for your FAT32 to give you one continuous volume. Lecter has a vid about it in his sig.
Ok. Well just to confirm, it will only work from recovery. In Clockwork, it must be the "mount as USB mass storage" option not "mount SDcard" option.
Android only mounts FAT32 (which would only show you the 6.35GB partition). Mounting in recovery as "SD card" will probably also do this, so you definitely need to pick the "USB mass storage option".
You can actually set the mount option before the USB is plugged into the PC, then you need to refresh the devices in Gparted to pick up the card as a whole (rather than an individually mounted partition)
Yes exactly. USB mass storage mounts the card. Mount SD or Mount SD ext will mount the individual mount points (the partitions) so you will only ever see the partition in question as a separate device.
Well assuming you have only usb mass storage mounted (and the mount sd card only says "mount /sd card" not "unmount /sdcard") not sure what else it can be.
A screenshot of gparted may help but the faff you would have to go through to get it probably wouldnt be worth it.
