Root A Phone call issue
I am using the very latest cm7 reloaded 3/4. When I flash new updates I always clear cache.
I have researched the threads and have found similar individuals with this particular problem, but haven't found a solution. When I'm actually making a phone call, and after the call is through, and I want to manually hang up, I have to press the power button to wake up the screen. This wasn't a problem in earlier reloaded flashes. But it has been for me, at least, for the last few releases.
I have tried a bunch of different Cm7 setting to no avail. What can I do to fix this?
It was showing up in the last few builds, but 3/4 should have it working again, try rewiping caches & reflashing the ROM. Also do a 'md5sum ROM.zip' to make sure the md5sum matches what I posted in post #1 of the thread.
