A printer to go with my infuse. ??
Looks like the HP is the only oem that sells their printers preinstalled to serve wireless needs for google cloud print. They r at walmart too. Any others om missing?
google cloud print works with any printer attached to a desktop/laptop running google chrome...everything is initiated through google chrome, with the cloud print extension/ add on enabled. set up allows you to print from literally anywhere in the world, as long as you and the desktop are online, and google chrome is logged in on the desktop..
Connect a printer to Google Cloud Print
as for straight up wireless printers...
http://www.google.com/search?rlz=1C...gc.r_pw.&fp=2bbe01f9b9f72b5f&biw=1639&bih=771
As long as the phone is on the same wifi network, Brother has a free app that works for printing pictures, .pdfs and scanning. Works like a champ and the brother printer that I have is printer / fax / scan and was only like $100 at Best Buy...
