Help a question about Panorama...
It can be changed. Long press the camera button and that will signal the last picture.
Correct - very nice option for those times you run into something you don't want in the pic, pan goes a long way, a lot longer than I expected.
TIP - careful with the light settings, if you don't have it set up correctly when you pan pic the light adjustment will change in each frame, when stitched together you can tell where it started and stopped.
