Guys, clock speed and voltage are *not* the same thing. Over/under
clocking is the process of changing your min/max CPU clock frequency. It basically makes things run faster or slower (that was an over-simplification
). Over/under
volting is when you either supply more or less voltage to the CPU. It has no affect on the clock speed, and does not make things run faster or slower. It impacts stability, only. If you undervolt, you have the potential to save battery life, but you could make the phone unstable. If you underclock, you have the potential to save battery life, but could make the phone slow. If you over-volt, you could make the phone more stable, but waste battery. If you overclock, you could make the phone faster, but waste battery. They are not the same, and do not necessarily rely on each other. Of course, higher frequencies require higher voltages. You can either supply a static under-volt, or go with HAVS, which will user lower voltages when the frequency is low, and raise them up at the frequency goes up. Generally speaking, the highest supplied voltage will be as low as possible to maintain stability at a given frequency. That being the case, unless you have stability issues, HAVS is your best bet if you want to under-
volt. Since you already have it, you're good. I believe netarchy also has a static under-volt kernel, as well, which will under-volt more than usual, but it will not change based on the frequency.
All that being said, I'm sure you may have heard that you've heard that you shouldn't use setcpu profiles if you're using HAVS. Some people may have seen some weird behavior, but it's likely not due to this. Setcpu profiles affect the frequency. HAVS affects the voltage, which is completely automatic, and will work at whatever frequency you have set.
