Hi Team,
I'm using my A100 as a Car Tablet (it's in the dash and working) but the problem is that the GPS is acting on me and looking if someone else is using it like that and has GPS issues or any recommendations for external GPS to use with it
The GPS antenna in the Iconias apparently are somewhat obstructed, so the internal GPS units tend to work better only in ideal conditions. A dashboard installation may be further blocking paths to the antenna.
It has the best reception and fastest acquisition of any GPS I've ever used, and the battery life is exceptional.
I tested my old Q818 with my tablet and it worked perfectly. That's no guarantee that the newer version will work the same, but the quality of the unit I have is very high, and I suspect the newer ones work just as well.
