I am running A2SD on my EVO. Mik3.11 and Anthrax v4 jus' in case it matters.
Is there a way to move just 1 app back to the phone / internal storage?
Thanks! -HN
I think with DTa2sd, it's all, or none.
Curious though.... why for come 1 app????
Edit: I assume you mean Dark Tremors a2sd and not the A2SD app correct?
Can you freeze that app with TB? I think you need the pro version to freeze apps tho. But worth it, I think.Yes, I'm running DT. The one app is creating a headache when I plug my phone via USB into my car stereo.
Is the app itself on sd card or just the sounds for it.I have the pro version already, and yes it is totally worth it!!
I don't think that would solve my odd issue. Here goes.
I have a lot of music on my phone, and a USB cable to connect it to my car stereo when I'm driving. Well, since Google Maps is on the card, when I mount the DD, it lists all of the sound files in Maps as songs. As luck would have it, they come 1st in the order and start auto-playing. So I'm cruising down the street waiting for the drive to mount, and all of a sudden my system starts blurting random navigation comands.....turn left, turn right, in 100 feet, in 500 feet, in 1000 feet, etc. Kinda annoying, so I want to move Maps back to the internal memory.
I found sound for maps on my card at:
/sdcard/Android/data/com.google.android.apps.maps/testdata/cannedtts/en_US.i.ae50f574
I know, long eh?
Wonder if you delete that last file, it would help, however, don't think you will have turn by turn anymore, or it would just repopulate the next time you open maps...![]()
