Tyseyh
Android Expert
Good Afternoon everyone.
I have a problem with my A2SD Storage.
As you can see, Internal storage is fine, as i was hoping, HURRAH!
But, the A2SD Storage really isnt. 4.21MB left out of 457 ( Which it was meant to be 512MB )
There is noway iv used all that space on my apps.
Though i must point out i did make the ex3 partition via ROM Manager, which i heard is a big no no but its the only way i can get it to work.
Gparted doesnt see my SD card, Partition wizard will create the partition but my phone then doesnt see it.
Also, if i remove the partition, remake it with partition wizard then re-flash my ROM, it will get to the lock screen and not show anything, even after leaving it for about an hour, Though making it with ROM Manager does. ( I had to flash leedroid to get ROM manager on to then flash my current rom Insert Coin.
Also, im looking at System Storage too, iv no idea why that is so low, any ideas?
Il give any more info that is needed but i think that should be enough.
Thanks guys and gals for any replies.
