I believe it's 12v. Check the sticker on the side of the tab. Mine fell off, so I can't check it.
Nope. Amps are just as important (it's the juice that can kill you) .Sorry to sound a bit dumb, but will the universal charger not be suffucuent to charge it up if set to the same voltage?
So I guess you've tried this on the A500 with a charger with almost 40% less amps & it actually charged?Rubbish, if the amps rating is lower than the supplied charger it just means that it will charge slower like an iPad. If you want the same performance as your original charger then go for one that is rated to at least 1.5 amps.
Pete
Just saw this old thread pop up because of the recent post.Rubbish, if the amps rating is lower than the supplied charger it just means that it will charge slower like an iPad. If you want the same performance as your original charger then go for one that is rated to at least 1.5 amps.
Pete
The same adapter is specified for use with the a100, a200 and a500... if that makes the search a little easier.Where can I buy this a 500 charger ...
OK - the power plug (mini usb or whatever you call it) seems to be same size as what we use on our Samsung phones - however those don't seem to charge it....they plug in fine but dont charge it - does this have to do with the amps and voltage thing???
