Root A500 Roms
Subzer0
:confused: Is there a reason why no one has posted any of the ICS Roms for the A500 on here? I've found quite a few at XDA, and have tried 3 of them with total success. Just weird that no one has put them on here. If anyone wants, I can add them to this forum too.
there are a few threads with links to Roms.
But, it would be great if someone could start a thread with links and descriptions.
Taboonay is my current rom.
As far as I can tell EVERYTHING is working. I have not seen any crashes and battery life is VERY VERY good.
Rom description from XDA
  • Stock Kernel
  • Rooted
  • Deodexed
  • optipng'ed & zipaligned apps to reduce size & memory usage
  • Busybox, Bash, Nano, sqlite3..
  • sysro, sysrw
  • Patch kernel from drellisdee
  • Insecure boot (adb remount)
  • Removed Acer bloatwares
  • VM tweaks
  • Ext4 tweaks
  • Modded host file for ads filter
  • Dalvik tweaks
  • Updated Apps
  • Acer Iconia Tab Bootanim
  • Asus Weather widget
  • Asus Task Manager widget
  • Asus eMail widget
  • Moto Weather Widget (from Xoom2)
  • Acer UI available (Acer Ring + Unlock Screen) disable by default
  • Launcher, SystemUI, Framework-res and Settings tweaks
  • Enabled more dev options in Settings
  • Added Acer Print with Browser and Galery support
  • New Acer Bookmarks widget
  • Added LiveWallpapers
  • Added TerminalEmulator
  • init.d support
  • PolarisOffice moved to /data
  • Include FaceLock
  • WiFi Add-Hoc support
Removed :
Acer About, AcerClockWidget, AcerNidus, Acer Registration, Acer Sync, Acer Sync Helper, DocsToGo, Hero Of Sparta, Lets Golf, LumiRead, NFS, TegraZone, TopGames, Zinio, Acer Media, clear.fi
hope this is alright to post.
i use an app called "acer recovery installer". it is a paid app but it does have a good list of roms and it will back up and install a rom of your choice.
you have to do the leg work yourself and read up on the rom if you are unfamilliar with it.
I cannot seem to find a paid version of Acer Recovery Installer... I have put a link to the free app in the sticky at the top of the All Things Root section.
Once you've installed a custom recovery, it is pretty easy to make backups and flash ROM's though, so it shouldn't be an issue!
Just a note:
Descriptions and links to the developer's original thread are fine, but please don't copy-and-paste the OP from another site. Not only is it a breach of copyright, it hotllinks the downloads which puts strain on AF's servers.
Thanks.
Oops, my bad. Sorry
